My new Rx7 R1
Tube that runs into the oil pan? The only thing that should be in the oil pan (other than oil, duh) should be the pickup tube with screen, dipstick, and low level sensor. The oil returns for the turbos are on the passenger side of the block and connect to the iron and front cover.
it's really hard to see in the picture what you're talking about.
The OEM knock sensor can be hit or miss in my opinion, I usually dont trust them much. That being said, that is rather high, you might want to make sure it's screwed in tightly into the front housing and looks intact. Other than knock, the sensor can also indicate a bad motor mount or other engine vibrations.
The knock sensor is usually screwed into the front housing on the drivers side, it's right above the top spark plug. Inspect it to make sure it still has all the black goopy stuff in the back of it where the wire comes out. That stuff deadens it a bit so its not as sensitive. Also make sure it's torqued in to the correct amount, but I forget what that is right now lol. That being said, I did that and it didn't help me at all, and it was a brand new sensor lol. It may help you though. The stock sensor is known to be way too sensitive and pretty much useless. Still makes tuning kinda difficult sometimes though.
As far as oil, I usually use a synthetic blend 10w30 and while there are endless debates about what's best, I think you'd be alright with a number of different weights and brands. That should work fine for you.
Cool thanks il give the sensor a check, would you reccomend changing it with an aftermarket one? and sweet thanks again man
speedjunkie wrote:The knock sensor is usually screwed into the front housing on the drivers side, it's right above the top spark plug. Inspect it to make sure it still has all the black goopy stuff in the back of it where the wire comes out. That stuff deadens it a bit so its not as sensitive. Also make sure it's torqued in to the correct amount, but I forget what that is right now lol. That being said, I did that and it didn't help me at all, and it was a brand new sensor lol. It may help you though. The stock sensor is known to be way too sensitive and pretty much useless. Still makes tuning kinda difficult sometimes though.
