Headlight restoration
Have you guys bothered with any kits ie; turtle wax and 3m. Which is the best? Or do you have any other suggestions?
- AuroraAxela
I had damn good results with meguiars
Mortose wrote:I used a kit a few years ago on my tiburon, just made it worse. so i just went and had it done professionally. Most car care places offer it. I've even seen it at tire shops.
thats why im hesitant, wouldnt it be sanding off the protective coat with one like turtle wax?
Ps, i brand new here and will probably have thousands of questions. Got my 3 beginning of Feb. and im in love.
- I`m Batman
- SecondGenPAt
- I`m Batman
Okay I'm here to settle this.
I "cleaned" my headlights with the turtle wax headlight restoration kit using a power wheel attached to a corded drill. I tried to fix my dad's 98' Pontiac with the same kit and nothing happened...
So I went out and bought some wet sand paper from an automotive store and sanded teh shit out of them. When I was done sanding they were clear as from the factory. I spent like $10 on sandpaper and $13 on the kit. If the places you talk to can beat that price go for it!
Regulator wrote:Okay I'm here to settle this.
1,000 grit?
- AuroraAxela
_AlexTM wrote:thats why im hesitant, wouldnt it be sanding off the protective coat with one like turtle wax?
The Meguiars kit has a UV protection coat in it.
And since I do these restos at work and at home, if you do get a kit, make sure it has the UV stuff.
papadelogan
- Junior Member
I've heard good things about the 3M kit but when I did this on my Outback years ago, I used a jitterbug sander and at least 1,000 grit wetsand paper. Once I got them clear/back to factory, I clearcoated them and never messed with them again. Something with UV protection sounds like the way to go, so when I do it again, I'll look for something with UV protection.
- I`m Batman
Users browsing this forum: Google [Bot] and 174 guests
