Damn you did more to relocate your relay box than I did haha.
I think they should have used a dual pass radiator too. I wonder if it would have cost more or something.
New FD in Town!
Got a little break from the field, so I dropped the UIM, TB, Turbo housing and the cool side charge pipe from Defined for polishing. He's only charging me for the UIM and Compressor Housing everything else is on the house. I already polished the charge pipe but it wasn't to the polisher standards and he took it from me lol.
Also installed my Hallman MBC, Extended the fan connectors, did some maintenance on the engine harness, tried to install my short shifter then realized that the oem shifter collar was gone lol, Installed Prosport boost gauge.
I also ordered a bunch of stuff for when i get back from the field: 8an hose, fittings, weld in bungs, oil filter adaptor, water temp gauge, wastegate spring 11 psi, hks ground kit, polished LIM
Im back from the field and ready to start working on my car, I've received a lot of parts including a Moroso breather tank, water injection bung, fittings, braided hose, water temp gauge, shifter bushing kit from Atkins, polished LIM and other random stuff.
I'll be getting all my parts from the polisher tomorrow and i'll be able to start putting the FD back together.
Here are the pics this guy did an outstanding job, I was really amazed with the quality of work.
Dave, sense my filler neck is already made out of metal I'm just going to weld a 6an bung to it and run the line to a catch can. That's it, it shouldn't be a lot of oil going inside the catch can any ways.
- boosted12a
donde hicieron eso? se ve bien!!!!
VRx8 wrote:Here are the pics this guy did an outstanding job, I was really amazed with the quality of work.
