It's time for me to put the Motor out of my flat black RX-7 for sale.
What's included:
Motor
-83-85 12A large street port built by Rotary Warehouse. The motor has about 30k on it and runs great. The motor has upgraded apex seals, I'm almost positive they are RA Super Seals. FD side seal springs The motor started up and ran great from the beginning.
-stock oil pump so stock oil pressure
-new FC 13B water pump and FC 13B housing
-Racing Beat oil pan baffle
-OMP
-oil to water cooler
-all sensors.
-depinned engine wiring harness
Fuel
-true RB holley 465cfm sp setup that I bought new
-Racing Beat Holley intake
-Racing Beat air filter assembly with K&N air filter
-quick change seconday springs upgrade
-electric choke upgrade
-center hung bowls upgrade
-Heatshield
-holley fuel feed line
-holley fuel pressure regulator with guage
-carter competition series external fuel pump 72 gph 8 psi
-3/8" SS fuel line from the tank to carb
-relay setup for pump.
-The carb was rejetted and AP jet rejetted
-Over $1k invested into the intake setup.
Exhaust
-Racing Beat 12A single out header
-custom 2.5" pipe
-2 magnaflow mufflers
-bung and plug for O2 sensor
Other
-Racing Beat lightweight Steel flywheel for an 83-85 12A 225mm (no longer availible)
-exedy stage 1 clutch
-Ford Taurus 3.8 2 speed electric fan
-Painless Wiring Fan Control 195 Degrees On/185 Degrees Off kit mounted to back of water pump housing
-FC S4 alternator
I'm also throwing the tranny in. The tranny needs a rebuild but has a new front cover. The tranny is a free addition so I will not drop the price if it is not wanted.
$3000 firm
FS Large Street Port 12A Complete
This is what it looked like when the car was still all together:
I will get pics of the motor the way it sits now this weekend.
Why is there a frisbee on top of your motor?
That's the air cleaner, lol
That was funny.
Eric
2 Fords 29 & 2000.
99 BMW 328i
THANKS! To all who serve.
2 Fords 29 & 2000.
99 BMW 328i
Bump...
Bump......
Sale is pending.
I should have the second half of the payment on Wednsday and be shipping on Friday.
Motor is SOLD
The update from the buyer:
PK_12A wrote:So just wanted to let you know,
Got the motor in and running and she sounds and runs beautifully, I love it. Hope the paint is coming along good for you man can't wait to see it.
Pat
