My New Toy
I received the windshield trim mounting clips and the Unleaded Fuel Only sticker last night. That was the last of the stickers I needed.
"Tow" sticker? Seems like a good one for you rotary guys. I kid, Chris' car runs (haha).
http://ts4.mm.bing.net/images/thumbnail.aspx?q=1620081576739&id=503524c4907d014d97dc0787b3739507&url=http%3a%2f%2fi876.photobucket.com%2falbums%2fab323%2fr_m_willis%2f2011%2520Corvette%2520Grand%2520Sport%2f100_1798.jpg
no ricer stickers for me, lol. I'll get a pic of them.
Shadowden wrote:"Tow" sticker? Seems like a good one for you rotary guys. I kid, Chris' car runs (haha).
"Tow Here" GREAT!
Could make that arrow look a little more like a rotor!?!
Eric
2 Fords 29 & 2000.
99 BMW 328i
THANKS! To all who serve.
2 Fords 29 & 2000.
99 BMW 328i
I spoke with the paint guy. Body work is getting done. The car still needs the front end cut off. I have the list of parts I need to buy and I'll be ordering everything today. I'll post my order list later.
RX-7 Chris wrote:I spoke with the paint guy. Body work is getting done. The car still needs the front end cut off. I have the list of parts I need to buy and I'll be ordering everything today. I'll post my order list later.
That's great. How is he stripping the car? Is it going to metal? The body work thing is very curious to me.
He isn't sanding it down completely to bare metal. He is basically sanding it far enough into the paint to give the new paint something to grip to. By sanding the paint he is able to find any imperfections that are too small to see otherwise. He said those little imperfections will be very easy to see when the paint is very glossy. After he is done with the sanding and filling, he will be putting down a coat of buildup primer and then sand that. Once he has all that done it is into primer and paint.
Parts are ordered:
-Column Cover Upper Brown
-Column Cover Lower Brown
-Door Seal Left
-Door Seal Right
-Window Seal Outer 2
-Window Seal Inner 2
-Channel, Glass 2
-Rear Hatch to Body Seal
-Sunroof Seal
-Emblem Front
-Emblem Rear
-Emblem Side RX-7/Logo 2
-Emblem (GSL-SE) Rear
-Emblem Retainer Clips 11
-Nozzle (L), Washer-Front
-Nozzle (R), Washer-Front
-Gasket Key Cylinder 3
-Gasket (R), Mirror
-Gasket (L), Mirror
-Screw, Mirror 2
-Screw, Mirror 2
-Screw, Mirror 2
-Windshield Wiper Washer, Cup 2
-Windshield Wiper Cap, Seal 2
Windshield Wiper Bushing, Outer 2
-Clamp, Hose 4
-Clamp, Hose 6
-Hose, Water Upper
-Hose, Water Lower
Total cost just shy of $800 (time to pass out now)
-Door Seal Left
-Door Seal Right
-Channel, Glass 2
-Sunroof Seal
-Emblem Front
-Emblem Rear
-Gasket (R), Mirror
-Gasket (L), Mirror
-Screw, Mirror 2
-Screw, Mirror 2
-Screw, Mirror 2
-Clamp, Hose 4
-Clamp, Hose 6
-Hose, Water Upper
-Hose, Water Lower
The front is cut off the car. I went over last night after work to help a little. I cleaned the radiator and helped with sanding and taping. The first layer of primer was laid last night after I left.
Saved the best for last:
Yes the layer of primer he laid is the high build. He had two other layers of primer to do before he starts on the base coat. the new front end will go on today or tomorrow.
