I was originally planning on hanging on to most/all of this stuff, but I am quickly running out of space so I need to clear it out as I really have no need for it anymore. Will get some pictures up soon!
Misc brand-new OEM gaskets: $50: Came with my Atkins rebuild kit, these are all OEM Mazda gaskets, includes all gaskets associated with the twin turbos, OMP crush washers, all emissions device gaskets (EGR, ACV, AWS, etc) etc. Can buy in a set or piece by piece, let me know what you need. (I am keeping the main gaskets such as the LIM, UIM, front cover, TB, etc)
Used FD exhaust manifold gaskets: $50. These are $150 a piece brand new from Mazda so I'm selling a complete set (2) for $50 bucks, these are used however. Still plenty of life, very good gaskets, I just got new ones with my rebuild kit so I'm using those.
Complete Bose trunk system (FD): $175. Complete Bose Acoustic-Wave trunk system with "snake", carpet, rear valence/shelf, and all wingnuts/hardware for a complete install. Everything is in great condition, Bose unit worked when uninstalled. Would be willing to trade for non-Bose rear carpet and valence/shelf.
Power Steering pump: $20. No longer needed as I delete my PS. Pulley is broken so you will need a new one. Does not include lines.
Pettit Upgraded FD twin turbos: $150. I originally thought these were smoking and causing my issues but it turned out to be the motor, however I can't guarantee these won't smoke, hence the lower price. Minimal shaft play. There is some cracking on the secondary turbo side, but it isn't terrible (I've seen much worse). These are upgraded units from Pettit Racing so they are worth rebuilding IMO. Includes all actuators.
Fluidyne aluminum -10AN oil cooler: $65. I purchased this off eBay in hopes of using it on the FD but is won't fit well so I'm moving on. It is used but in great condition and very clean. Has two -10AN male fittings on the side, one fitting does have a SMALL dent/ding on the flare. I can't personally verify if it leaks or not as I haven't tested it, but the selling company on eBay assured it didn't. Approx dimensions are 15" wide x 8" tall x 2.75" thick. This is a very good cooler that is easily worth double or more what I'm asking, I just got a good deal on it so I'm passing along the savings.
I have some stuff I'm sure I'll come across so I will update this and post pictures later.
Thanks!
FS: FD gaskets, twins, complete Bose, oil cooler, etc
Finally got some pics, also found some other stuff for sale:
Exhaust manifold gaskets, $50:
Gasket set (mostly stock twins), $50:
Stock air pump, works great, connector has the locking tab broken but still works fine, $25 bucks:
Brand new eBay T4 single turbo manifold, I cut off the 4-bolt w/g flange so it's ready to weld on your w/g flange of choice, $90 bucks:
Pettit Racing stock twins 3" downpipe, heat wrapped, includes O2 bung for stock sensor plus WB02 further downstream, $95 bucks:
OEM twin turbo brick manifold, does have a broken stud (any machine shop should easily be able to remove it, but mani is priced accordingly), $35
Pettit upgraded stock twins, unsure if they smoke or not (motor was smoking), includes all actuators. Does have some cracking, great core, $150:
Also selling the TiAL Q Blow-off valve, this is BRAND NEW, never used, purchased from Real Street Performance (authorized TiAL dealer), comes with box and every fitting like you bought it new. Purple, $225 bucks:
Misc gaskets have SOLD
Also have some other stock FD stuff:
-Stock driver side (touring) oil cooler with brackets and hoses: $35 bucks
-Stock FD clutch with pressure plate, probably less than 3k miles but not for sure, in great shape: $65 bucks
-Stock FD flywheel, great condition (want local sale): $25 bucks
I am flexible on prices, the TiAL BOV will work on all FI cars that want to run a VTA BOV and it's brand new!
