Q. Transmission overheats
A. Probable causes: A, I, G, H, N, J, M, L, 2, 3, 4, 5, 6, 7, 10
Q. Oil emission and/or white smoke while running
A. Probable causes: A, I, D, N, G, H, J, M, 2, 3, 4, 5, 6, 7, 10
Q. Abnormal odor from oil charging pipes
A. Probable causes: A, N, 1, 2, 3, 4, 5, 6, 7, 10
Q. Transmission noisy in "P" and "N" ranges
A. Probable causes: A, G, 5
Q. Transmission noisy in "D", "1", "2" and "R"
A. Probable causes: A, G, 1, 5, 8, 10
The Transmission / Differential FAQ
[color="RoyalBlue"]For current updates and event coverage check out[/color] [SIZE="3"]Whizbang Rally's Facebook[/SIZE]
spare
you probably should show where you got the info.
RX-7 Chris wrote:you probably should show where you got the info.
i added a statement at the beginning! Let me know if its good enough.
that works
