The Transmission / Differential FAQ
Whizbang
Postby Whizbang » Thu Dec 08, 2011 9:14
Updated: 21 Mar 2010
The following is a coming together of information for quick reference when looking for a gear ratio, transmission choice or any other information that may assist those looking to modify or repair there drive line. This thread will be updated periodically and reference to that will be via that date at the very top of this thread. Information is gather from product manufacturers, Mazda technical manuals and specifications, various repair manuals and research on my and other enthusiasts parts.
[color="Red"]Transmission Gear Ratios[/color]
Q. Can i use a Ford or Chevy transmission?
A. Yes, a couple of companies make adapters and bell housings to allow for a spread of transmissions including the Ford T5, various Chevy transmissions and Jericos.
See this thread here regarding swapping a T-5: T-5 Swap
For the Ford T5 see Rotaryshack or Kennedy Engineering.
For Chevy transmissions see J.W. Performance Transmissions Page 17
For Jerico transmissions see J.W. Performance Transmissions Page 17
For VW transmissions see Kennedy Engineering
[color="RoyalBlue"]For current updates and event coverage check out[/color] [SIZE="3"]Whizbang Rally's Facebook[/SIZE]
Whizbang
Q. Are there aftermarket gear sets for my stock transmission case?
A. Yes,Pfitzner Performance Gearboxs (PPG) makes several options. OSGiken also makes sets for the FD3S and FC3S Turbo II.
  • 5 speed dog engagement gearset
  • Series 1-5 billet shifter platform
  • Short shifter assembly
  • Hardened billet selector fingers
OSgiken
3 Speed Kit for the FC/FD:
1st: 2.714
2nd: 1.742
3rd: 1.267
5 speed kit for the FC/FD:
1st: 2.578
2nd: 1.772
3rd: 1.289
4th: 1.000
5th: 0.821
Q. What about the Miata gearset swap?
A. See this thread here for some good information: Miata Gears
Q. Can i swap an Rx8 Transmission?
A. Yes, but read this thread throughly first: Rx8 Transmission
Whizbang
[color="Red"]Factory Transmission Ratios[/color]
[color="Red"]Please note that the there can be variances in the fifth gear of the transmission depending on the sales market (Japan, USA and UK)[/color]
Mazda Rx2, Rx3, Rx4, Rx5 (Cosmo) 12A/13B Gearbox
1st: 3.380
2nd: 2.002
3rd: 1.390
4th: 1.00
5th: 0.791
Mazda Rx3SP 77-78 Gearbox
1st: 3.380
2nd: 2.002
3rd: 1.390
4th: 1.00
5th: 0.791
Mazda Rx-4 77-78 13B Gearbox
1st: 3.380
2nd: 2.002
3rd: 1.390
4th: 1.00
5th: 0.791
Mazda Rx-5 (Cosmo) 77-78 13B Gearbox
1st: 3.380
2nd: 2.002
3rd: 1.390
4th: 1.00
5th: 0.791
Mazda Rotary Engined Pickup 74-75
1st: 3.683
2nd: 2.263
3rd: 1.397
4th: 1.000
Mazda Rotary Engined Pickup 76-77
1st: 3.683
2nd: 2.263
3rd: 1.397
4th: 1.000
5th: 0.862
Mazda Miata Gearbox
1st: 3.136
2nd: 1.888
3rd: 1.330
4th: 1.00
5th: 0.814
Whizbang
89-93 B2600 "R" Transmission
1st: 3.730
2nd: 2.158
3rd: 1.396
4th: 1.000
5th: 0.816
Mazda Rx-7 early 12A Gearbox (4spd)
1st:
2nd:
3rd:
4th:
Mazda Competition Rx-7 Gearbox
1st: 2.350
2nd: 1.608
3rd: 1.240
4th: 1.00
5th: 0.881 or 0.839
Mazda Rx-7 79-83 12A Gearbox
1st: 3.674
2nd: 2.217
3rd: 1.432
4th: 1.00
5th: 0.825
Mazda Rx-7 79-85 Automatic Transmission (L4N71B)
1st: 2.458
2nd: 1.458
3rd: 1.00
4th: 0.720
Mazda Rx-7 84-85 12A Gearbox
1st: 3.622
2nd: 2.186
3rd: 1.419
4th: 1.00
5th: 0.758
Mazda Rx-7 84-85 13B (Type M) Gearbox
1st: 3.622
2nd: 2.186
3rd: 1.419
4th: 1.00
5th: 0.807
Mazda Rx-7 86 13B 6PI (Type M) Gearbox
1st: 3.475
2nd: 2.002
3rd: 1.366
4th: 1.00
5th: 0.711 (0.758 UK)
Mazda Rx-7 87-88 13B 6PI (Type M) Gearbox
1st: 3.475
2nd: 2.002
3rd: 1.366
4th: 1.00
5th: 0.697 (0.758 UK)
Mazda Rx-7 87-88 13B Turbo (Type R) Gearbox (also the 929)
1st: 3.458
2nd: 2.015
3rd: 1.391
4th: 1.00
5th: 0.762 (0.806 Japan)
Mazda Rx-7 89-92 13B 6PI w/o LSD Gearbox
1st: 3.475
2nd: 2.002
3rd: 1.366
4th: 1.00
5th: 0.697
Mazda Rx-7 89-92 13B 6PI with LSD Gearbox
1st: 3.475
2nd: 2.002
3rd: 1.366
4th: 1.00
5th: 0.756
Whizbang
Mazda Rx-7 89-92 13B Turbo Gearbox
1st: 3.483
2nd: 2.015
3rd: 1.391
4th: 1.00
5th: 0.719
Eunos Cosmo 90-95 20B-REW JATCO Automatic
1st: 2.78
2nd: 1.54
3rd: 1.00
4th: 0.69
Eunos Cosmo 90-95 13B-REW JATCO Automatic
1st: 3.03
2nd: 1.62
3rd: 1.00
4th: 0.69
Mazda Rx-7 93-95 13B-REW Gearbox
1st: 3.483
2nd: 2.015
3rd: 1.391
4th: 1.00
5th: 0.719 (0.806 Japan)
Mazda Rx-8 04-current 13B Renesis Gearbox (manual)
1st: 3.815
2nd: 2.260
3rd: 1.536
4th: 1.177
5th: 1.00
6th: 0.787
Mazda Rx-8 04-current 13B Renesis Gearbox (automatic)
1st: 3.538
2nd: 2.060
3rd: 1.404
4th: 1.000
5th: 0.713
6th: 0.582
Whizbang
[color="Red"]Differential Gear Ratios[/color]
Q. Are the turbo stub shafts interchangeable?
A. Somewhat.
  • 89-92 have a longer right side and a short left side.
  • There is a vin split for the 86-88 shafts.. 608385+ are different the ones below that vin.
Q. I heard about the Kia Sportage and Mazda truck differentials, what are the facts about this?
A. I am going to break this up into two parts.
1. The Kia Sportage
  • Available in the pre-2002 Kia Sportage. 1997 may not have the 4.78, but i have not been able to confirm this. Also, there may be another ratio other than the 4.78, but again, i have not come across them.
  • The 3rd member is a direct bolt in to the 84-85 Rx7 axle housing.
  • It is an open differential. But a LSD unit meant for an 84-85 rx7 will work fine in it.
  • The holes on the kia member are larger than the Rx7 member, but it is not an issue.
2. The B2600
  • Come from the 1987-1988 4x4 5spd models. (front differential).
  • Gear is a 4.44 with an open differential.
  • Check for wear since these are older sets and usually not well maintained.
Mazda 79-82 12A: 3.909
Mazda 83-84 12A: 3.933
Mazda 84-85 13B: 4.076
Mazda 85 12A: 3.909
Mazda 86-92 13B 6PI / Turbo 5 speed: 4.10 UK models 4.30
Mazda 1988 Convertible: 3.91
Mazda 1989+ Convertible: 4.10
Mazda 86-92 13B 6PI Automatic: 3.91
Mazda 1989 GTUs 5 speed: 4.30
Mazda 93-95 13B-REW Manual: 4.10
Mazda 93-95 13B-REW Automatic: 3.91
Mazda 09-current 13B Renesis Manual: 4.777
Mazda 09-current 13B Renesis Automatic: 4.3
Mazda 04-08 13B Renesis Manual: 4.44
Mazda Miata 5 speed: 4.10 or 4.30
Kia Sportage 98-02 4x4 (front diff): 4.78
Mazda B2600 87-88 4x4 5spd (front diff): 4.44
Mazda B2600 87-88 4x4 Auto (front diff): 4.10
^^all of the above will direct bolt into the Mazda rear end. All are large spline differentials.
You can use an rx7 pinion seal in a kia sportage third member, its a little different design, but it will fit and so far has worked for me. I will update if any issues arise.
Availible Aftermarket Gears
see Mazdatrix.com for details
1979-1985
4.444 27-110A-M054
4.875 27-110A-1312
5.125 27-1100-1480
1986-1992
4.30 Non-turbo 27-110A-M066
4.30 Turbo 27-110B-P092
1993-1995
4.30 27-110A-P0A5
Notes:
  • 93-95 pinion is shorter than the 86-92
  • Short pinion on Rx2, Rx3SP and 79-85 Rx7
  • Long pinion on Rx3
[color="Red"]Input Shaft Information[/color]
Turbo: 1"x23 Spline (same as some Ford applications)
NA: 1"x22 Spline
Whizbang
[color="Red"]Limited Slip Information[/color]
Q. Where can i get rebuild parts for my OEM Limited Slip?
A. either the dealership or check Mazdatrix.com. The direct link is HERE
Q. What fluid should i use with my limited slip?
A. If it is a clutch type, then use a fluid that had additives for LSD or otherwise indicates it is safe for LSD use. Mostly higher quality fluids fall under this. Also, synthetic fluids is a good choice for any differential.
Mazda Limited Slip Units
Mazda Rx7 83 Clutch Type (GSL models)
Mazda Rx7 12A 84-85 Clutch Type (GSL models)
Mazda Rx7 13B 84-85 Clutch Type (GSL-SE) (Limited Slip is less aggressive than 12A model)
Mazda Rx7 13B 6PI 86-88 Clutch Type (GXL, GTU)
Mazda Rx7 13B Turbo 87-88 Clutch Type (Turbo II)
Mazda Rx7 13B 6PI 89-92 Viscous Type (GTUs)
Mazda Rx7 13B Turbo 89-92 Viscous Type (Turbo II)
Notes:
  • 1983 and earlier models do not interchange with 84-85 models. Changes in axle design do not allow the interchange.
  • Turbo LSD units do not interchange with Non-Turbo LSD units.
Aftermarket Torsen Limited Slips
84-92 Non-turbo ------ MZTX-TORSEN1
93-95 Twin Turbo ----- 27-200E-P099
Torsen Limited Slips per Mazdatrix:
These very unique torque sensing differential limited slip units are now available for 84 and later RX-7's. They really are the absolute best design for rear traction under ALL different conditions. It is able to transmit far more torque to the wheel that still has traction than any other type of differential. It uses the friction of the worm gear teeth and the thrust washers for the differential limiting force. In comparison with viscous type, or friction type LSD, it has the following benefits:
1) Large bias ratio torque proportioning
2) Less change of bias ratio over time of car use
3) No special differential oil or LSD additives needed
4) Improved overall traction and improved controllability under acceleration.
5) Virtually no change of torque sensing or traction control through differential temperature range.
Aftermarket "Kaaz" Limited Slips
Cost for Kaaz clutch type limited slip range from about 950 to about 1100 dollars.
WPC coating reduces the "clicking" and "clunking" noises associated with a strong working limited slip.
1.5 Way (Suitable for Road Racing)
  • 84-92 N/A -------------------- DBZ1810
  • 84-92 N/A WPC COATED ------- DBZ1810-WPC
  • 87-88 TURBO ----------------- SBZ1310
  • 87-88 TURBO WPC COATED ---- SBZ1310-WPC
  • 89-92 TURBO ----------------- SBZ1315
  • 89-92 TURBO WPC COATED ---- SBZ1315-WPC
2 Way (Suitable for Drifting / Drag Racing)
  • 84-92 N/A -------------------- DBZ1810-2
  • 84-92 N/A WPC COATED ------- DBZ1810-WPC-2
  • 87-88 TURBO ----------------- SBZ1310-2
  • 87-88 TURBO WPC COATED ---- SBZ1310-WPC-2
  • 89-92 TURBO ----------------- SBZ1315-2
  • 89-92 TURBO WPC COATED ---- SBZ1315-WPC-2
Whizbang
[color="Red"]Clutch Information[/color]
Clutch Diameters
Mazda pre-1982 12A / 13B: 215mm
Mazda 1983-1991 12A / 13B 6PI: 225mm
Mazda 1987-1988 13BT: 235mm
Mazda 1989-1991 13BT: 240mm
Mazda 1993-1995 13B-REW:
Mazda 04-current 13B Renesis: 236mm
***note: the S4 / S5 split has a 5mm difference STOCK. Performance clutches are all 240mm****
Types of Aftermarket Clutches
[color="Red"]Flywheel Information[/color]
Identifying Flywheels
There are several versions of the OEM flywheel over the years. Each has different diameters, weights and markings.
Weights are approx.
1978-1980 12A--------------30lbs-------None
1981-1982 12A--------------23lbs-------21 **this flywheel is thinner and lighter than the rest and has a different pressure plate requirement**
1983-1985 12A--------------26lbs-------31
1984-1985 13B (GSL-SE)-----26lbs-------N304
1986-1988 Non Turbo 13B----24lbs ------N326
1989-1992 Non Turbo 13B----21lbs-------N350
1987-1988 Turbo 13B--------27lbs-------N318
1989-1992 Turbo 13B--------23lbs-------N370
1993-1995 Turbo 13B--------20lbs-------N3A1
Lightweight (Aftermarket) Flywheels
Aftermarket lightweight flywheels are a modification that is somewhat of a double edged sword. A heavier flywheel, in general terms, provides a smoother ride, better idle quality and an easier start from stop. A lightweight flywheel requires less energy to get moving which translates to move usable power and a faster run through the rpm range. Downsides that this can be reduced idle quality and some shuttering while driving, especially with ported cars. Can also mean more wear on the clutch due to the change in driving experience from a stop.
When buying an aftermarket flywheel, ask your self a few questions:
1. Does the flywheel come with the counterweight?
2. If it does, is it the right weight for what i need?
There quite a number of options for all years of the rotary engine. Some will not provide a counterweight with the flywheel. This is an important component since aftermarket flywheels bolt to the counterweight. Now, just because it may come with a counterweight, doesn't mean its even the weight you need. The counterweight is critical to balancing of the rotating assembly and the wrong counterweight can and will attached to your engine, but will not be the proper one to use. The best thing to do is source your own and personally assure that its the one you need.
Brands of Flywheels
[color="blue"]ACT[/color]
ACT makes a nice flywheel in two different versions, BUT will only work with the turbo transmission. Also source your counterweight elsewhere since they are not well informed that different years require different weights.
Streetlite
  • Part #600145
  • 13.9lbs
Prolite
  • Part #600140
  • 9.8lbs
[color="blue"]Fidanza[/color]
Fidanza is yet another good option. They do not include the weight of the counterweight in their calculations and require you to source your own counterweight.
Lightweight Steel
  • 1987-1995 Turbo 13B Part #261941 18lbs
  • 2004+ RENESIS 13B Part #261801 18lbs
Lightweight Aluminum
  • 1986-1991 Non Turbo 13B Part #161991 8lbs
  • 1987-1995 Turbo 13B Part #161941 10lbs
  • 2004+ RENESIS 13B Part #161801 10lbs
[color="blue"]Guru[/color]
Guru produces a 4140 Chrome Moly flywheel that is probably the top of the line thing you can buy. It uses a 5.5" style AP, Tilton or Quartermaster clutches.
Technical Specifications
Flywheel:
  • Flywheel currently delivered for the RX7 Turbo case transmissions
  • RX7 Generation 1-3 (Series I-VI)
  • Direct fitment within bell-housing with no modifications necessary
  • No ring gear as teeth directly cut onto flywheel
  • Flywheel heat treated and black oxidised
Clutch:
  • Suit AP, Tilton and Quarter Master (QM) 5.5" clutch assemblies
  • Delivered with custom thrust bearings & mount as well as gearbox thrust bearing slider nose
Material:
  • All component are precision manufactured
  • 4140 Chrome Moly
  • Heat treated and black oxidised
Guru 4140 Flywheel
10.1 lbs
16lbs
OEM Turbo II
27 lbs
44 lbs
[color="blue"]Racing Beat[/color]
Racing beat sells an array of flywheels in either steel or aluminum. Their price includes the counterweight specific for your year and model engine!
Lightweight Steel
  • 1974-1982 12A Part #11440 16lbs (compared to 30lbs [74-80] / 23lbs [81-82] stock)
  • 1983-1985 12A Part #11441 16lbs (compared to 26lbs stock)
  • 1984-1985 13B (GSL-SE) Part #11442 16lbs (compared to 23lbs stock)
  • Rx-4 and Cosmo 13B Part #11450 16lbs (compared to 30lbs stock)
  • 1986-1988 Non Turbo 13B Part #11444 17lbs (compared to 24lbs stock)
  • 1989-1992 Non Turbo 13B Part #11447 17lbs (compared to 22lbs stock)
  • 1987-1988 Turbo 13B Part #11445 17lbs (compared to 28lbs stock)
  • 1989-1995 Turbo 13B Part #11446 17lbs (compared to 22lbs [89-92] / 19lbs [93-95] stock)
  • 1974-1982 12A Part #11452 12lbs (compared to 30lbs [74-80] / 23lbs [81-82] stock)
  • 1983-1985 12A Part #11456 12lbs (compared to 26lbs stock)
  • 1984-1985 13B (GSL-SE) Part #11457 12lbs (compared to 23lbs stock)
  • Rx-4, REPU and Cosmo 13B part #11453 12lbs (compared to 30lbs stock)
  • 1986-1988 Non Turbo 13B Part #11464 12lbs (compared to 24lbs stock)
  • 1989-1992 Non Turbo 13B Part #11465 12lbs (compared to 227lbs stock)
  • 1987-1988 Turbo 13B Part #11448 12lbs (compared to 28lbs stock)
  • 1989-1995 Turbo 13B Part #11449 12lbs (compared to 22lbs [89-92] / 19lbs [93-95] stock)
  • 2004+ RENESIS 13B Part #11468 12lbs (compared to 16.8lbs stock)
[color="blue"]OS Giken[/color]
http://www.osgiken.net/products/supersingle.html
[color="Red"]Counterweight Information[/color]
Identifying Counterweights
Series 5/6 (1989-1995) 0.498-0.510
Weight of Counterweights
4.0lbs
Whizbang
[color="Red"]Fluid Types and Capacities[/color]
***synthetics are recommended for use in all applications***
Transmissions (manual)
1979-1981 Transmissions: 1.8 qts. (1.7L)
1982-1985 Transmissions: 1.8 qts (1.7L)
1986-1991 Non Turbo Transmissions: 2.1 qts
Transmissions (automatic)
pre 1985 Japco automatic: 7.9 qts. from empty (7.5L)
Differentials
1979-1983 Differentials: 1.25 qts GL-5 SAE 90
1984-1985 Differentials: 1.6 qts GL-5 SAE 90
1986-1991 Non Turbo Differentials (Open): 1.4 qts GL-5 SAE 90
1986-1988 Non Turbo Differentials (Clutch Type LSD): 1.4 qts GL-5 SAE 90 (must have LSD safe additives)
1987-1988 Turbo Differentials (Clutch type LSD): 1.4 qts GL-5 SAE 90 (must have LSD safe additives)
1989-1991 Turbo Differentials (Viscous type LSD): 1.4 qts GL-5 SAE 90
Whizbang
[color="Red"]Troubleshooting (Manual Transmissions)[/color]
Q. Abnormal noise from transmission?
A. Probable causes:
1. Insufficient oil
2. Deterioration of oil quality
3. Worn bearing
4. Wear of sliding surfaces of counter-shaft gear
5. Wear of sliding surfaces of gears
6. Excessive gear backlash
7. Damaged gear teeth
Remedies corresponding to above:
1. Add oil
2. Replace oil
3. Adjust or replace
4. Replace
5. Replace
6. Replace
7. Replace
Q. Difficulty shifting?
A. Probable causes:
1. Bent change rod
2. No grease in transmission control system
3. Insufficient oil
4. Deterioration of oil quality
5. Wear or play of shift fork / rod
6. Wear or poor contact of synchro ring or synchro cone of gear
7. Excessive play in gears
8. Wear of bearing
9. Wear of synchro key
10. Improper disengagement of clutch
1. Replace
2. Add grease
3. Add oil
4. Replace oil
5. Replace
6. Replace
7. Replace
8. Adjust or replace
9. Replace
Q. Jump out of gear?
A. Probable causes:
1. Bent change rod
2. Weak / broken lock-ball spring
3. Wear of shift fork
4. Wear of clutch hub or hub sleeve
5. Wear of gear sliding parts
7. Wear of bearing
8. Loose or broken engine / transmission mounts
1. Replace
2. Replace
3. Replace
4. Replace
5. Replace
6. Replace
7. Adjust or replace
8. Fix / Tighten
Q. Gear shift lever difficult / rough?
A. Probable causes:
1. Sticking control rod
2. Malfunction of ball joint on control rod
3. Bent change rod
1. Replace
2. Replace
3. Replace
Whizbang
[color="Red"]Troubleshooting (Auto Transmissions)[/color]
Chart of Inspections (w/o disassembly)
A. ATF quality
B. Range selector linkage
C. Inhibitor switch and wiring
D. Vacuum diaphragm and piping
E. Kickdown solenoid, switch and wiring
F. Engine idling speed
G. Oil Pressure
H. Engine Stall Speed
I. Rear lubrication
J. Control valve
K. Governor valve
L.. Band servo
M. Transmission air check
N. Fluid inspection
O. Ign. switch or start motor
P. Engine adjustment and brake inspection
Chart of Inspections (after disassembly)
1. Rear clutch
2. Front clutch
3. Brake band
4. Low and reverse brake
5. Oil pump
6. Hydraulic circuitry
7. Torque converter one-way clutch
8. Power train one-way clutch
9. Parking gear mechanism
10. Planetary gear
Whizbang
***inspections for probable causes are in order from most likely to least likely***
Q. Engine does not start in "P" or "N"
A. Probable causes: O, B, C
Q. Engine starts in ranges other than "P" or "N"
A. Probable causes: B, C
Q. Excessive "N" to "D" range shift shock
A. Probable causes: F, D, G, J, 1
Q. Vehicle does not move in "D" but does in "1, 2, R"
A. Probable causes: B, G, J, 8
Q. Vehicle does not move in "1, 2, D" but does in "R" / Very poor acceleration
A. Probable causes: A, B, N, G, J, M, P, 1, 6, 2
Q. Vehicle does not move in "R" but does in "1, 2, D" / Very poor acceleration
A. Probable causes: A, B, G, N, J, M, 4, 2, 1, 6
Q. Vehicle does not move in any range
A. Probable causes: A, B, G, N, J, M, 5, 6, 9
Q. Power transmission slippage felt when starting
A. Probable causes: A, B, G, N, J, D, M, 5, 6
Q. Vehicle moves in "N" range
A. Probable causes: B, N, J, 1
Q. Low max. speed / Poor acceleration
A. Probable causes: A, B, N, G, H, L, J, P, 3, 4, 1, 2, 5
Q. Vehicle braked when "R" range selected
A. Probable causes: N, M, L, 1, 3, 9
Q. Excessive creep
Whizbang
Q. No creep at all
A. Probable causes: A, B, F, N, J, 5, 6, 1, 2
Q. Does not shift from 1st to 2nd gear
A. Probable causes: B, D, E, N, J, K, M, L, 3, 6
Q. Does not shift from 2nd to 3rd gear
A. Probable causes: B, D, E, N, J, K, M, L, 2, 6
Q. Excessively high 1-2, 2-3 shift points
A. Probable causes: D, E, G, N, J, K,
Q. Shift directly from 1 to 3
A. Probable causes: N, J, M, K, 3, 6
Q. Excessive 1-2 shift shock
A. Probable causes: D, H, N, J, L, 3
Q. Excessive 2-3 shift shock
A. Probable causes: D, G, J, M, L, 2
Q. No 1-2 shift shock or slippage
A. Probable causes: A, B, D, G, N, J, M, L, 3, 6
Q. No 2-3 shift shock or slippage / Engine runaway
A. Probable causes: A, B, D, G, N, J, M, L, 2, 6
Whizbang
Q. Vehicle braked when shifted from 1 to 2
A. Probable causes: N, J, 2, 4, 8
A. Probable causes: N, L, J, 3
Q. Does not shift from 3 to 2
A. Probable causes: D, N, J, K, M, L, 2, 3, 6
Q. Does not shift from 2 to 1 or 3 to 1
A. Probable causes: D, N, J, K, M, L, 3, 8
Q. Shift shock once accelerator is released and vehicle is decelerating
A. Probable causes: B, D, E, G, J, K, 2
Q. Excessively high 3-2, 2-1 shift points
Q. Does not kickdown in 3 within kickdown limit
A. Probable causes: E, D, N, J, K, 3, 6
Whizbang
Q. Abnormal rise of engine speed and/or kickdown in 3 outside kickdown limit
A. Probable causes: B, D, G, N, J, K, M, 2, 6
Q. Engine runaway or slippage from 3 to 2
A. Probable causes: D, G, N, J, M, L, 2, 3, 6
Q. Does not shift from 3-2, with "D" to "2" range shift
A. Probable causes: B, G, N, J, L, 3, 6
Q. Shifts from 2-1 or 2-3 in "2" range
Q. No shift shock / Engine runaway in "1" to "2" range shift
A. Probable causes: A, B, D, F, N, J, M, H, 3, 5
Q. No 3-2 shift in "3" to "2" range shift
A. Probable causes: B, G, N, J, K, M, L, 2, 3, 6
Q. No engine braking in "1" range
A. Probable causes: B, G, N, J, M, 4, 6
Q. Shifts from 1-2 or 2-3 in "1" range
A. Probable causes: B, J, 6
Q. Does not shift from 2-1 in "1" range
A. Probable causes: A, B, N, J, K, L, M, 4, 6
Q. Excessively large 2-1 shift shock in "1" range
A. Probable causes: D, H, N, J, 4
Q. vehicle moves in "P" and/or parking gear not disengaged when "P" range is disengaged
A. Probable causes: B, 9
Users browsing this forum: No registered users and 19 guests
