My House Remodel Projects.
Postby speedjunkie » Mon Nov 21, 2011 9:14
So one staircase per year? LOL
Postby RX-7 Chris » Mon Nov 21, 2011 9:14
I know, I'm slow.
Postby RX-7 Chris » Mon Nov 28, 2011 9:14
I have the decorative stringers and the risers installed and primed. I need to do some light sanding and a coat of white paint. The treads will be installed this week.
I'll get some pics up this week.
Postby RX-7 Chris » Mon Dec 05, 2011 9:14
Here are the stringers and risers installed:
Here is where I was on Saturday:
I have more of the treads installed now but that is the last pic I took.
Postby kingtut » Mon Dec 05, 2011 9:14
oooo....ahhhh
Thanks for the pics! (finally...)
Postby speedjunkie » Mon Dec 05, 2011 9:14
Looks good!
Postby Shadowden » Mon Dec 05, 2011 9:14
Nice job chris!
Postby tsx_guy » Thu Dec 08, 2011 9:14
i concur sir!
ecam8000
Postby ecam8000 » Fri Dec 09, 2011 9:14
Is that a hand carved baluster? I liked the 4x4, but this one is more to the wifes liking.
Eric
2 Fords 29 & 2000.
99 BMW 328i
THANKS! To all who serve.
Postby RX-7 Chris » Fri Dec 09, 2011 9:14
It isn't a hand carved newel. I actually bought it preassembled.
http://www.stairwarehouse.com/4091-flat-panel.html
I actually bought all the newel posts here. This one is a 6x6 but all the others are a 3 1/2x3 1/2. http://www.stairwarehouse.com/4075-3-5--box-newel.html
They are a great company with quick shipping and good pricing. The quality is very good. The 3 1/2x3 1/2 are solid and the 6x6 is hollow. To install the 6x6 I used 2x's to attach to the floor structure and than I attached the newel to the 2x's. There is quite a bit of construction adhesive holding it together as well as 2 1/2" finish nails. I added the 2 screws you see in the pics as just an added attachment, they will be covered by the oak paneling I'm building.
Postby RX-7 Chris » Mon Dec 12, 2011 9:14
I've been making progress but is had been slow going.
List of what to do this week in order:
-sand treads and risers
-stain treads, min 8 hours to dry
-seal treads, 2 coats, min 2 hours between coats but not more than 6
-install next newel on balcony (the one above the column)
-install first section of rail at balcony
-install oak paneling on floor stucture by stair
-install oak nosing
-install balisters and rail
Postby speedjunkie » Mon Dec 12, 2011 9:14
Man this stuff looks like fun. I want to start upgrading my place soon. I may need some advice when that time comes haha.
it is fun at times but a ton of work. I can give you advice when it comes to that.
Postby RX-7 Chris » Wed Dec 14, 2011 9:14
I picked up a Ryobi Corner Cat finish sander last night so I could get in the corners to sand down the filler. It was for sure worth the $30 it cost. It saved me hours of work.
The treads were sanded and refilled last night. Tonight I will be doing the final sanding and I plan to get the next newel post installed. Tomorow night will be the staining and friday will be the 4 coats of sealer. The sealer has to cure for 3 days before we car really walk on it so we will be using a ladder through the weekend.
