Sure Motorsports Anchors
Postby Colombia28 » Wed Oct 26, 2011 9:14
I finally got myself a set of shift bushings. I had them years ago but they went with a parts trade I did with another member. I ordered the Sure Anchors last Friday and they came the following Tuesday! Awesome shipping time. Granted there isn't much to a set of aluminum shifter bushings, but these are pretty cool. Maybe it's just the color. Heck even the packaging is really cool. Sure is a pretty sweet new manufacturer. Check then out if you haven't yet.
If you don't have a set of bushing yet kick yourself right now. I can't believe I have gone so long without having them. It's been nearly three years since I traded them away (stupid!). So glad to have a set again, they really do make a noticeable difference in shifting feel. Far less notchy. Still not perfect, but they have made things a bit smoother between gear changes. For example, I would say that 90% of the time with the stock bushings my 1 -2 gear change would be notchy, never grinds, but would be consistently notchy and feel awful. With the new bushings I would say it's only 30% of the time notchy. All other gear changes are less notchy now too.
Pretty cool color!
Matches my Cobb short throw
And the stock ones. Notice how some of the steel inserts are deformed....
Do yourself a favor and order a set if you don't have them already. Really worth the small price.
Mikedubs
Postby Mikedubs » Thu Oct 27, 2011 9:14
Welp, that's all the convincing I need, is that a short shifter there too?
COSpeed3
Postby COSpeed3 » Thu Oct 27, 2011 9:14
i have these also, didnt feel that much of difference. if you really want to feel a difference in the shifting get the SURE CounterShift and the SURE ShortCut
http://www.suremotorsports.com/products/countershift
http://www.suremotorsports.com/products/shortcut
for the price two of the best mod's you can do to your car.
Cobb–Access PORT
Cork Sport-FMIC,Intake,Inlet
Edge-Insight CS Scan Tool
Innovate-LC1 Wideband Gauge
Luminics-Fog,High Beams
RPM-Vent Pod
Turbo Smart-Dual Port BOV
Turbo XS-TBE[/SIZE]
RichB
Postby RichB » Tue Nov 08, 2011 9:14
I've seen a bunch of different products that are exactly like the ShortCut and noticed that people had binding issues with the cables shift. The ShortCut doesn't have these issues?
Postby Shadowden » Tue Nov 08, 2011 9:14
Man, that Cobb Shifter is solid. Love the looks. Did it decrease knob height much?
As fas as a shift plate vs. shifter, thats a tough one. The smaller counterweight is interesting, but if decreasing size and weight on that area of the system is good, why not just remove it entirely? (probably a real noob question there).
COSpeed3
Postby COSpeed3 » Tue Nov 08, 2011 9:14
RichB wrote:I've seen a bunch of different products that are exactly like the ShortCut and noticed that people had binding issues with the cables shift. The ShortCut doesn't have these issues?
yeah, i did at first but just had to bend the cable alittle bit.
Cobb–Access PORT
RPM-Vent Pod
Turbo XS-TBE[/SIZE]
Postby Colombia28 » Mon Apr 16, 2012 9:14
Shadowden wrote:Man, that Cobb Shifter is solid. Love the looks. Did it decrease knob height much?
Looks like I did it again, I missed your question ages ago. Sorry man. It does decrease knob height, but not the crazy amount some other short shifts do. Mine is at the lowest height (it's adjustable for height of the knob and throw), and I think it's just right.
Users browsing this forum: Google [Bot] and 146 guests
