I have a quick question about the boost tables that are in ATR. Looking at the Boost Targets, are these sea level targets? I ask because I have an Aeroforce Scan Gauge and I have the boost set to be zero'd out at our ambient pressure here in Denver. Is this how it should be set up in order to match the boost tables in ATR?
For those of you who plumbed your own boost gauges, when you target a boost PSI in ATR is that what your guage shows or is it a few PSI lower due to the altitude?
Boost Tables in ATR
Boost Tables in ATR
RichB wrote:I have a quick question about the boost tables that are in ATR. Looking at the Boost Targets, are these sea level targets? I ask because I have an Aeroforce Scan Gauge and I have the boost set to be zero'd out at our ambient pressure here in Denver. Is this how it should be set up in order to match the boost tables in ATR?
My car always has had the mechanical boost read 2 psi lower than the Map Sensor. Right now the mechanical reads 23 psi and the Map sensor logs 25 psi. I chalk this up to the mechanical showing actual boost as built from 12.5 atmospheric pressure here and the Map Sensor logging boost as if the atmospheric pressure is actually 14.7 or sea level. I am likely wrong about that but I do know that the mechanical will always read about 2 psi lower. Also under ATR there is a boost table that will adjust boost based on atmospheric pressure. If you just run a straight OTS AP map at our altitude you will see less boost than is being called for by the map.
The boost target shouldn't care about altitude. It will try to hit that boost regardless of where you are. It will just have to work harder to hit that target up here versus sea level.
Even the boost-targeted OTS maps? I would think they would still try to hit their target boost regardless of altitude.
Now load-based maps will definitely hit lower boost up here than at sea level because they're not trying to hit a certain boost level at all.
DSM If you turn your ignition on (without starting the car) what does your mechanical gauge read? If it shows something in the area of -2 psi then I think the mechanical gauge is set for sea level and the MAP sensor accounts for altitude.
Which table in ATR accounts for the altitude? Its not the Boost Target one is it?
My mechanical reads 0 and always has regardless of tune or boost gauge. I will check for the table.
Edit: There is a table called Boost Table: Boost Comp - baro.
Also there are tables that cut fuel and close throttle based off the atmospheric pressure as well. Thos have to be watched. I tuned my car at 5500 ft and forgot to check the cut and throttle close tables. went up to 6500 ft and instead of a steady 22psi I was bucking and cutting @ 16psi because of the baro tables. Not fun and blew an entire day from my road trip.
The Boost Tables will only really be relevant if you have boost tuning checked under options.
erod550 wrote:Even the boost-targeted OTS maps? I would think they would still try to hit their target boost regardless of altitude.
I haven't messed with Boost Based Tuning. i have heard very good things though. I slogged through 4 months of Load Based Tuning before I became frustrated and went MBC. The little Joe P I have on there now hold 24/25 psi fine with almost no spike. I may delve into Boost Tuning again though so I can limit the boost in the first 3 gears as spinning 1st through third is getting old.
I am just confused now. Yesterday I was holding 19 psi when my boost targets are currently set for 16 (my safe map). When I look a little deeper I should have hit boost cut at 18 psi. Even with load based tuning, if I hit the boost limit it should cut right?
Are you using Boost Based tuning or Load Based?
Also was it a spike? If so the boost cut takes a second to kick in.
I am trying to do boost based but I'm not sure if I checked that box in the settings. I will make sure tonight.
I was definitely holding 19 psi but it scared me when I saw it so I might have released the throttle before the cut. It should cut up there though even with load tuning right?
RichB wrote:I am trying to do boost based but I'm not sure if I checked that box in the settings. I will make sure tonight.
It should. You should take a 4th gear log if you can so we can see exactly what its doing. You should be ok @ 19 psi I had my k04 hitting 21 psi in the mid range. The concern is that your boost cut is not kicking in.
Ok, I will see if I can get a log at some point soon.
I'm not worried about hitting 19 psi since my goal is to hit 18 psi at some point in the future. What worries me is that my current map was supposed to be at stock boost settings so I can work on my fuel targets. Then I happened to see 19 psi on a pull and it worried me even more when I saw that my fuel cut is set to 18 psi.
Is it possible that the Boost Tune logic isn't active even when my map is based off of an OTS BT map?
I just checked, the Boost Tuning checkbox is checked in my ATR options. I'll capture a log and see if my AP logs different boost values than my gauge.
Dsm, you say your mechanical gauge is 2 psi low? Does your AP log the higher value?
The factory boost pressure sensor should be a PSIA type sensor which is an absolute sensor which accounts for atmospheric pressure as part of it's readings. So it should never actually read "zero".
Most consumer type boost gauges are PSIG type sensors so they will not account for atmospheric pressure; they will only read the amount of pressure you add over ambient.
Which brings me back to my original question. When looking at the boost tables in ATR or boost from a data log, are the values absolute pressure minus 14.7 (sea level pressure)? Or is it the psi above ambient?
I'm beginning to think that my gauge is reading psi difference from ambient while my MAP is using absolute minus 14.7. If that's the case, my gauge would show about 18.5 psi when my MAP sensor reads 16 psi which is exactly what my AP map is targeting. This makes complete sense because to get 16 psi up here at 6k feet, the turbo would have to work as hard as pushing 18.5 psi at sea level. This means that up here in Denver, the stock K04 is only efficient up to 19 psi (absolute - 14.7) instead of 21psi like it is at sea level.
I will try and confirm this with a log. If I'm right, when I boost target in ATR I will set it about 2 psi lower than my true turbo load target.
Users browsing this forum: No registered users and 155 guests
