headed to the darkside...
BRC
Postby BRC » Mon Sep 05, 2011 9:14
I was able to bleed the stupid thing but it was very time consuming. It consisted of, jack car up on driver side, crawl under and feel around for the bleeder screw, loosen screw, climb back up and press pedal to floor, crawl back under car, feel around for bleeder and tighten screw, climb back out, pull pedal up, and repeat the process... about ten times. It was a good exercise in paitence. Meanwhile I did get the cooling system 99% finished, tapped the steam tube into the top of the water pump housing, got a belt on, and finished the pcv system. Still need to get the pcm re-flashed if anybody knows who can do it out of the vehicle.
PXRdriFT
Postby PXRdriFT » Mon Sep 05, 2011 9:14
I've sent several PCM's to Jesse Bubb in Indiana. Last thing I sent out to him though was my LS2 PCM two years ago. I paid $100 with lifetime tunes. Not sure what his prices are now. He usually has your PCM out same day he receives it for limited downtime.
http://www.wait4meperformance.com/
BRC
Ill check it out. Do you know anybody in town?
BRC
Postby BRC » Tue Sep 13, 2011 9:14
cleaned up the motor a bit with some flashy new covers...
before...
[ATTACH]2033[/ATTACH]
after...
[ATTACH]2029[/ATTACH]
[ATTACH]2030[/ATTACH]
OBD2 port hiding in the glove box...
[ATTACH]2031[/ATTACH]
and got a shifter finally. Factory Hurst for $40...
[ATTACH]2032[/ATTACH]
The shift knob should arrive tomorrow
BRC
shift knob
[ATTACH]2034[/ATTACH]
Postby chickenwafer » Tue Sep 13, 2011 9:14
Looks good man. Maybe it's some kind of optical illusion but the motor looks angled slightly off center?
BRC
chickenwafer wrote:Looks good man. Maybe it's some kind of optical illusion but the motor looks angled slightly off center?
Its probably because it dosent belong in there...lol
truely its an illusion, in person its a whole different animal.
PXRdriFT
Postby PXRdriFT » Tue Sep 13, 2011 9:14
I had that same knob on my last motor. Felt great. Sorry I missed your earlier question. Never looked in town. I just always went with Jesse. I always got it back within 5 days of sending it.
Postby RX-7 Chris » Wed Sep 14, 2011 9:14
It's looking really good.
BRC
Postby BRC » Thu Sep 15, 2011 9:14
finally finished the gauges, all stock gauges work with the exeption of the speedo, that'll have to be replaced with an Integra unit to read the electric signal instead of cable. Pcm flash is scheduled for thursday next week. Still waiting on a driveshaft.
BRC
Postby BRC » Sat Sep 17, 2011 9:14
had a quick flash done to disable VATS. Itll get the full flash next week but it runs & drives now and it is epic. Still need to finish the last bit of cooling and exhaust but if all goes well I might have it dirvable for next weeks meet.
Postby iani1.1 » Sat Sep 17, 2011 9:14
wow, nice.
BRC
driveshaft
[ATTACH]2038[/ATTACH]
fits perfectly!
Postby RX-7 Chris » Sat Sep 17, 2011 9:14
wow that is a short driveshaft.
Postby speedjunkie » Sun Sep 18, 2011 9:14
^I literally just said the exact same thing out loud and then scrolled down and read what you wrote LOL.
