My new car!
RX-7 Chris wrote:isn't that the crankcase vent?
chickenwafer wrote:Yes, I believe it is.
Uh oh.
RX-7 Chris wrote:Why would someone block the crankcase vent? Usually not a good thing.
Actually I've had my capped for quite a while, back when this engine was originally in the car, and I didn't have any problems. The filler neck also serves as a vent too though, and that's what I've been using. Maybe I'll pop the cap off this one too though and see what happens.
chickenwafer wrote:^It's really that easy? I was all worried I was going to have to grab a copper wheel for my bench grinder and spend 5 days cleaning them. Thanks for the tip!
I think I read somewhere that the rotors have a special coating on them that can be taken off with wire brushes and all that...unfortunately I read this AFTER I took a wire brush to my rotors already haha. I could be wrong though, not sure.
VRx8 wrote:Yeah i did, is 719-205-8604.
Thanks! Updated haha.
speedjunkie wrote:I think I read somewhere that the rotors have a special coating on them that can be taken off with wire brushes and all that...unfortunately I read this AFTER I took a wire brush to my rotors already haha. I could be wrong though, not sure.
I don't believe this to be true. Every professional who rebuilds these motors for a living I've talked to says to used a wire brush to clean them if they are heavily carboned. Use a copper brush if possible.
The group buy finally got in motion so I ordered my v-mount today. Went with the Defined Autoworks kit. Can't beat the deal- it includes all the standard v-mount affair (radiator, intercooler, plumbing) plus everything is mounted on heavy duty steel mounts with rubber isolators to prevent cracking of the cores.
The kit also includes ducting, which is the key to an effective v-mount, and is one of the only kits out there to do so. I also got the optional A/C brackets so I can attempt to retain my A/C system.
I'm pretty stoked! The build is making slow but steady progress.
Stripped all emissions stuff from the UIM and LIM today. The ACV system was CAKED with oil sludge all inside the LIM. It's such a narrow passageway I'm not sure how I can effectively clean it...pipe cleaner perhaps?
After I got all the emissions stuff off, double-nutted the studs and removed them, then installed the Banzai block off plates with some gasket goo. Also put blue Loctite on the Banzai-supplied bolts to ensure they won't back out.
The only item I didn't delete in the Banzai kit was the ISC (Idle Speed Control) so I can still maintain a somewhat acceptable idle. So I deleted the AWS, AWS Tube, ACV, ACV tube, thermowax, double throttle (the butterflies in the UIM were a BITCH!), split air, and EGR.
Also might be picking up an FD part for a steal pretty soon...
Haha yeah me as well. I used a screwdriver and it stripped them, even tapping the screwdriver with a hammer did nothing, just stripped them The bolts have massive thread locking compound on them (as I've been told) because you obviously don't want them popping out and flying into your motor. But really, Mazda should have used allen head cap bolts or something other than a phillips head!
I had to drill them out as well.
Users browsing this forum: Baidu [Spider] and 85 guests
Glad everything looks to be in good shape.
