New - Local information please...
generalfred
Postby generalfred » Fri Jul 15, 2011 9:14
Hey guys! I'm new to Colorado... Moved here from Orlando, Fla. Are there any good local speed shops that do dyno tuning? That do high performance engine builds? Tranny work? Any recommendations?
Also, as far as the altitude and emissions testing... I'm looking to rebuild my motor. Would it be wise to look for C.A.R.B. approved parts?
Really what I'm getting at is in Florida, it's at sea level, and there's no emissions testing. I have no experience with tuning in regards to either. I'd like to find a shop that's built high performance motors AND knows what parts (cams, ecu's...etc) I can use and still pass the emissions test.
Any insight would be great, and I look forward to seeing you guys online!
Postby Learjet45 » Fri Jul 15, 2011 9:14
Is this for your CX-9, or do you have other cars as well you're looking at doing stuff to?
I don't know a ton about the local shops, but I've been on the forums long enough to learn that MAC Autosports is a popular choice (but their dyno numbers can be pretty inflated).
Another option is Revolutions Performance down in Colorado Springs, which is a bit far.
Also, for emissions testing, what county you live in will make a difference. I don't know what county Westminster is in, but I do know that not every county does emissions testing.
http://www.colorado.gov/cs/Satellite/Revenue-MV/RMV/1185957917898
That page has the info on which counties do emissions testing.
Postby erod550 » Fri Jul 15, 2011 9:14
Regarding emissions testing, as long as you still have cats, you are pretty likely to pass. They're not that strict.
That too. I have a copy of the emissions test from my Legacy for the title paperwork, and I was looking at some of my values compared to the limits, and I was thinking "holy bajeebus that's ridiculously high compared to the level". Granted, it is a PZEV model, but still, it kinda surprised me.
dsm_luck
Postby dsm_luck » Fri Jul 15, 2011 9:14
You just need a catalytic converter usually. Also if you fail the first time put 3 to 4 gallons of E85 in the tank. It will help you pass.
Are you trying to modify the CX-9? What are your goals?
generalfred
Yeah, sorry. It's for a 91 Miata (stock). I also live in Jefferson Co. Pretty sure they do have emissions testing.
Reason I was asking, was because I wanted to put in some cams, maybe do the head... I'd keep the cats on. I figured a tuning shop that built decent motors would have a general idea as to what stuff will pass.
I've been in love with the idea of a nice NA motor but from what I've been reading, forced induction is the way to go out here....
Yea you will be disappointed with the gains on an NA motor at this altitude. Boosted is the way to go. My Mustang has about 75hp less than its sea level counterparts, which shows up in my best 1/4 mile time of 13.31 @ 109 modded when people at sea level are running 12.7 @ 112+ stock.
Dange
Postby Dange » Fri Jul 15, 2011 9:14
generalfred wrote:Yeah, sorry. It's for a 91 Miata (stock). I also live in Jefferson Co. Pretty sure they do have emissions testing.
I dunno how much ya know about the miata and its engine so ill let you know what ive found. if you are already set on what you want, feel free to ignore my advice.
last miata i was building as an na motor. 1.6 with intake header racepipe, exhaust. and a light flywheel . i hit 100whp on a mustang dyno. so im guessing around 115-120 on a regular dynojet, which isnt bad for a 1990 with 100k miles. I was going to keep going but fate didnt agree with my plans and the car was totaled out right before i joined the army.
highest built n/a miata was about 184rwhp at sealevel. it was quick but that was a built engine stroked to 2.0L, high compression pistons, 9-10k revlimit, and individual throttlebodies. and the bits he used came from fujiracing. guy probably had 10k in his engine minimum
finding good cams is gonna be a pain. integral and fuji both recently closed their doors. and they were the best. theres a few n/a build cams but for the price its not really worth it. 800 bucks for maybe 15hp... with the 1.6 you can get a greddy turbo for 800 used or 1300 new and get over 30hp gains only thing possibly worth the money in this department is the intake exhaust cam swap which is cheap if you can get a junkyard doner. but only like 5hp in the upper end. for a days worth of work.
headwork. will help some. but if you are spending that much money try to find a 1.8 and preferably a 99 head because they flow as well as a early 1.8head that has been ported.
and for around same price and you will make more power than a 1.6 with minor engine work. this will bring up the price of the turbokit if you go that route. but begi's s1 is still pretty cheap. or you could try and find a msm engine/ turbo kit and use that. (1.8 bottom end. 99 head. upgraded cams all stock)
If you are set on the feeling of a built na engine. i rode in a whipple charged built 1.8 miata that was damn impressive, so smooth and the sound was glorious at full throttle. at this altitude that may be your best bet. look at FastForwardSuperchargers, begi, and jackson racing
the FFS kit being a coldside system will feel almost identical to a built NA engine. but with a sexy whine.
but the JR system can be upgraded with an intercooler and smaller pully easier. but probably will only get to the same HP levels the FFS will come with out of the box.
BEGI is good but doesnt come with fueling so thats a downfall. however BEGI and FFS are the only two that i know for a fact are carb legal. .. So i would go with the FFS kit just for those reasons.
mod path i would suggest, (yes i suggest alot of ebay bits, but the few that i do suggest are the ones that have been tried and tested and hold up. and if they do fail by some ungodly reason wont kill your car. and are just as good as their counterparts that cost 400% more)
ebay/vatozone intake. (for now untill you decide on aspiration.. and its its 10 bucks for some sound and a little power increase)
4-1 header either jackson racing get the ebay for 106 bucks and free shipping.. most the guys seem to like the 4-1 better than the 4-2-1
get a pipe made with a highflow cat beware It WILL be loud as hell and even more so if you supercharge which is why im going to suggest the next exhausts
obx/tsudo exhausts. very nice sound with stock header/cat will be slightly louder but still reasonable with header and testpipe
obx if you like to stay stealthy looking
[ame="http://www.youtube.com/watch?v=yxZwLTGUK6c"]here[/ame] this one has a header and a highflow cat so itll be the volume and sound of what you can expect to hear.
and tsudo n1 if you like a cannister style muffler. and the two basically sound the same.
corksport is good too,
[ame="http://www.youtube.com/watch?v=A4Xu2Zk07Dk&feature=related"]here[/ame], its a little louder but still quiet compared to most cars. (im a little proud of that one because i was the pivot man to get that exhaust into production.
04MSMGT
I wonder if that FastForward power number of 170whp is just with their kit and everything else stock? Hmm.....
Dange
from my understanding yes.
04MSMGT
generalfred
Dange,
Thanks for the wealth of information... I'll probably hit you up once I get a little closer to the actual engine build.... An HKS turbo kit for around a $1000? Where?
I was going to get a Raceland header, but after reading your post... It would probably be better to get something that people here (on this board) have tried.
As far as exhaust, I was looking at the Corksport Drift, or the Fujitsubo Legalis-R. Both ore supposed to be fairly loud, which I don't really care about too much... I live near the entrance of the neighborhood anyway. Any thoughts on these? ...Oh, and a Magnaflow cat. I haven't decided on an NA intake yet... I won't do anything internally until the spring unless something happens before then.
Erod550,
The altitude here is a killer! A sec. is a lot to loose. I have noticed a HUGE loss of power in the CX-9... I'll tell you what though... after being here for 7 months, I wouldn't go back to Florida if you paid me...
Dange
its not HKS its greddy for the 1.6l miata. its really simple small turbo/low boost setup but 30additional hp is quite a jump from the approx 90hp you have now at the crank.. I would be affraid to dyno a stock 1.6l at this altitude. with drivetrainloss and altitude. id be guessing around 60-70ish whp.
the turbo kit seems to have gone up in price a bit actually.
with a begi FPR, and add an intercooler injectors and bpv you can bump from 5ish psi up to around 7-10 and get at almost stock msm power.
plus you loose 15-18% at this altitude vs the 23%+ you loose NA
and if the car is ONLY a fair weather fun car (never take a trip in) its really easy to loose some weight on the car. which is what this car is great for.
the raceland is pretty much a marked up e-bay 4-2-1 header. id go with the cheap 4-1 ebay setup. the m.net and cr guys tend to really like it.
corksport drift is loudish with a header and no cats. but it is not hondacivic nomuffler loud or harleydavidson loud. I would say it is more than noticeable. but because theres little to no rasp, or buzz and as long as you arent driving like a hoon through the neighborhood youll be fine. plus CS drift supposedly nets a 8hp gain according to their dyno.
fujitsubo i havent looked into because they tend to be needlessly expensive (im seeing $549+sh for a used example i paid that much for my new 2.5" magnaflow turbo exhaust.) they sound great, and the rm-01a sounds good if a little more rasp than i like...
if you like quiet but a good tone. stay with the cheap obx, or go with something like jackson racing, or flyinmiata's offerings.
04MSMGT
generalfred
Postby generalfred » Sat Jul 16, 2011 9:14
Yeah, I think a low boost turbo on the stock motor (internally) is the way to go... I'll just run it until it blows then worry about it.
I'll pretty much use the car in town... maybe some day trips to the mountains.
Thanks for the help and advice. I'll keep researching....
Dange
Postby Dange » Sat Jul 16, 2011 9:14
engine is basically the same as the 323GTX a factory turbocharged engine. so the engine loves boost. your rods are good up to 250whp pistons should be good for 30-50 over that. the reason its not a higher boost set up is you need fueling and an ecu to go past that level.
i wouldn't worry too much about getting near the 200hp range. ive been running at around 225 for almost a year now.
04MSMGT
generalfred
Thanks for putting me on to those turbo kits. The one I had found was around $1600, and didn't come with an intercooler. I don't remember if it came with any type of air/fuel controller.
My biggest issue is the emissions... I've never had to deal with them before. I turbo kit and a mild tune would be nice, but I'd hate to have done all this and fail. That's my only concern.
