Cp-e High Flow Fuel Pump Information, With Dynos & Datalogs!
arctic_blue83
Postby arctic_blue83 » Sun Dec 16, 2007 9:14
Well, over on Mazda6club (which I haven't posted on in a while before today) apparently someone (Dadasracecar) installed CP-E's new high pressure fuel pump on his Mazdaspeed 6. Take a peak:
http://forum.mazda6club.com/index.php?showtopic=88367
^^^If I'm not mistaken, the FP helped to richen things up about a half a point in the lower RPMs (same lean spot I used to have) as well as eliminate fuel cut. That's right, no more fuel cut. Imagine that... hey Josh, remember when you were on the dyno, and I kept telling Nick I didn't think your fuel cut had anything to do with the MAF or MAP inputs, but that I believed your car was just running out of fuel and/or maxing the fuel pressure sensor/spill valve?!? I think this just about confirms my theory. Your fuel cut wasn't MAP related... the only reason why it stopped somewhat was because Nick pulled enough MAP voltage that it caused your car to pull fuel and run lean. Which would explain why you kept having fuel cut problems at very odd RPMs (up top), where you weren't producing peak boost, and your MAF/MAP values were just fine, like all cars, as RPMs increase, so does the need for fuel, I would be willing to bet you were just running out of fuel. Just my $.02
Anyway, good info!
Postby SpeedRacer » Sun Dec 16, 2007 9:14
Goodpoint dude very good point :)
Brocksdad
Postby Brocksdad » Sun Dec 16, 2007 9:14
Very interesting. I am trying to get Mike to get that fuel pump so we can turn up the boost.
Users browsing this forum: Google [Bot] and 171 guests
