Took the car for a drive today, got a question.
christi
Postby christi » Sun Jul 03, 2011 9:14
Car now has 436 miles on her. To be totally broken in, I need to have 1000 right?
I went for a drive today, drive was nice, besides the soon to be rain. She drove awesome, slight hesitation, but nothing to worry about. The car drives smooth on small inclines, but when going up on a larger incline she has issues. Like, i have to be in 1st up until the top (cave of the winds).
Would this be somewhat normal? I remember I could climb her in 2nd gear on the old motor. The temp stayed reasonably low... it might have climbed a bit, though.
When she idles, it sounds as if something is rubbing. I dunno, it could be me, but I doubt it. It rubs also when I turn, but I'm thinking the turning part is part of my P/S.
Otherwise the car runs good... I don't take her out but only on weekends, so that's why she's not broken in yet.
After I get home, the friggen top won't work. I've had this issue before, which is why I still believe I have a electrical issue. If you stop at ANY point, you can only go down, and it'll stop working. Last time I had this issue, it took me 20-30 minutes to get the top up. Any ideas?
Also, a bit off topic, but does anyone have 1-2 jackstands and a jack I can borrow? The vibrating I get in regards to my wheels being bent to hell, I want to put on the crappy dial-wheels to avoid any wear/tear for now.
Oh, and her starting up this morning. She just.. wouldn't stay idle. She sounds like shit, because I have stock exhausts and another exhaust leak, yay!
[ame="http://www.youtube.com/watch?v=ABu4qjS-eII&feature=channel_video_title"]YouTube - ‪Rx-7 1990 'vert‬‏[/ame]
13B n/a Street Port
Goopy performance
2005 Mazda 3
nothin' but stock love.
alex_n/a
Postby alex_n/a » Mon Jul 04, 2011 9:14
don't forget you lost low end torque. I need 4th on the freeway to even speed up a little bit. And that's going 55mph at 2500rpm in 5th gear. Pretty much any gear below 3k is powerless for me.
you also lost more low end torque because of your straight pipe. One day you should drive my car to feel the difference. When I had my exhaust leak it was almost like running an open header. After fixing it. I felt a noticeable power increase below 3k.
I have tons of jack stands. And a jack. Feel free to come on over if you are in aurora. Pm me if you want my address/number.
Postby Number2 » Mon Jul 04, 2011 9:14
So it idles like that normally? Did it do that before you swapped the engine?
christi
Postby christi » Mon Jul 04, 2011 9:14
Paul: Yeah. It was still cold when it was idling. I didn't get the clip of her trying to die and I had to pump the gas pretty good for it to stay alive. Haven't had that in a while.
Alex: next time I'm in denver will be for the cruise next week, that could work, haha. Yeah, but I didn't have a huge loss of low end torque previously and I had the straight pipe on the old motor. I wonder if it's because the butterfly values (6-port sleeves) have been removed.
13B n/a Street Port
Goopy performance
2005 Mazda 3
D Walker
Postby D Walker » Mon Jul 04, 2011 9:14
Its because of the 6 port actuators and the fact the S5 runs rich as all hell and needs correcting :)
christi
And by correcting = the standalone eh? I can't afford that any time soon right now... may have to do when i get next year's tax return.
However, as I just texted you don, It sounds as if something is rubbing. I have NO idea how to explain it. I can let you test drive it, and then see what I'm talking about. I do know I'm off Saturday, if you'll be at your shop I'm happy to come by and show you.
Kinda worrying me though.
13B n/a Street Port
Goopy performance
2005 Mazda 3
D Walker
Actually no standalone needed, just a simple SAFC will work just fine.
christi
Safc or the II? Even then I'm stupid when it comes to these things. Doesn't the safc need a laptop or is that the powerFC? Either way I've gotta wait til a bit of money comes in. Still the safc wot explain the rubbing I hear/feel when driving. Hopefully you're not too busy Saturday to look at it. I should be in Denver then.
13B n/a Street Port
Goopy performance
2005 Mazda 3
christi
Postby christi » Sat Jul 23, 2011 9:14
Same idle issue but better quality for the noise that's coming anytime she tries to idle
...anyone know or do I need to get a better sound clip? This is coming from inside the car.
http://m.flickr.com/photos/frogmeow/5968426303/
Edit:
Inside the car is where my phone was but it is definitely coming from the bay, somewhere. You can distinctly hear it when you poke you head inside the engine bay but not as much as inside the car.#
13B n/a Street Port
Goopy performance
2005 Mazda 3
christi
Postby christi » Sun Jul 24, 2011 9:14
So.... after digging, it was the heat shield that is coming off, joys. :P
13B n/a Street Port
Goopy performance
2005 Mazda 3
Users browsing this forum: Google [Bot] and 76 guests
