headed to the darkside...
Postby iani1.1 » Tue Jun 28, 2011 9:14
wow nice find
alex_n/a
Postby alex_n/a » Tue Jun 28, 2011 9:14
light bulbs cost more than that lol... good find
^^haha true.
im soo getting these for mine though
http://www.elef-usa.com/apps/webstore/products/show/1200287
BRC
Postby BRC » Wed Jun 29, 2011 9:14
so after a long wait and even longer conversation with jegs and painless it turns out the harness has been discontinued and I cant get it through them. So now ill just wire it up the hard way and use the refund to get more parts instead.
BRC
Postby BRC » Sat Aug 27, 2011 9:14
so its been a while since ive had a chance to work on the rex, had to rebuild the top end of the Range Rover, but after that nightmare I was able to focus on the 7 again and with a little wiring.... The ls1 roared to life! the open-header monster belched fire and came to life for a whole 3 seconds... then it shutdown. fired it up again and it roared to 2000!!! then shutdown again... did it 3 more times then triple checked all the wiring. I now belive that since the engine was removed from a firechicken the VATS was never disabled. So now its time to disable the security in the ECM and a couple other things while im in there...skip-shift...rear O2...purge...etc... After that we'll see if it will idle for more than a few seconds. The driveshaft, clutch master, and all lines will be in hopefully soon but if its anything like the last time I ordered from Hinson it'll probably be a month.
Postby iani1.1 » Sat Aug 27, 2011 9:14
nice to hear some progress.
Postby RX-7 Chris » Mon Aug 29, 2011 9:14
You need to hurry and get the car done and take it to a meet or cruise.
BRC
Postby BRC » Mon Aug 29, 2011 9:14
just got the driveshaft today! still waiting on clutch hydro though, hopefully that'll arrive in the next day or so.
BRC
Postby BRC » Thu Sep 01, 2011 9:14
Clutch parts arrived so now time for the installation. Should have everything finished and operational soon then its just the pcm flash.
alex_n/a
Postby alex_n/a » Thu Sep 01, 2011 9:14
nice, can't wait to see this driving on the streets
BRC
All the clutch parts are in and work great! BTW I dont know how much room is in the transmission tunnel of an F-body but when a t-56 is crammed into the chassis of an FC there isnt much room to bleed the slave cylinder... not much room for anything else either.
The master & res. fit nicely in the corner. It dose however have a MUCH stiffer pedal now.
Wilwood 7/8 master w/ DOT5
Postby RX-7 Chris » Fri Sep 02, 2011 9:14
Frank put a remote slave bleeder on his car that's really cool.
Postby speedjunkie » Fri Sep 02, 2011 9:14
^Super Street said the previous owner did that LOL!!!
BRC
Postby BRC » Sun Sep 04, 2011 9:14
when the time comes to replace the clutch and slave i think i will make a remote bleeder just for simplicity.
PXRdriFT
Postby PXRdriFT » Sun Sep 04, 2011 9:14
yea i made the bleeder. probably my best mod!!! i couldn't bleed the clutch otherwise.
