alcohol /water kit
COSpeed3
alcohol /water kit
Postby COSpeed3 » Thu Jun 16, 2011 9:14
Cobb–Access PORT
Cork Sport-FMIC,Intake,Inlet
Edge-Insight CS Scan Tool
Innovate-LC1 Wideband Gauge
Luminics-Fog,High Beams
RPM-Vent Pod
Turbo Smart-Dual Port BOV
Turbo XS-TBE[/SIZE]
dsm_luck
Postby dsm_luck » Thu Jun 16, 2011 9:14
COSpeed3 wrote:Anyone running a kit like this?
http://www.alcohol-injection.com/universal-stage-1-8.html
I have the Snow version of that kit mixed with some Devils Own parts. It makes a big difference if you are running more boost. I run a 65/35 methanol/water mix and I will sometimes see BATs hit 15 below ambient on a hot day. I recommend a trunk mount, bigger reservoir, and d04-d05 nozzles. d03 might be too small and D07 too big for the K04. If you have any questions or would like to see how I ran my setup just let me know.
COSpeed3
Postby COSpeed3 » Fri Jun 17, 2011 9:14
thanks man, yeah i would like to check it out.
Cobb–Access PORT
RPM-Vent Pod
Turbo XS-TBE[/SIZE]
dsm_luck
Postby dsm_luck » Fri Jun 17, 2011 9:14
COSpeed3 wrote:thanks man, yeah i would like to check it out.
PM me I go up to the springs from time to time.
reconbygod12
Postby reconbygod12 » Sat Jun 18, 2011 9:14
id check the percent of meth before you run it...you'll need a tune
2008 wrx sedan-new love
09 cwp mazdaspeed 3 GT-gone
04 mazda 6s-gone
Postby erod550 » Sat Jun 18, 2011 9:14
You can inject water/meth without a new tune. It just won't take advantage of the extra octane, so you won't see much of a power boost, if any. But you'll still have the cooling/cleaning effects.
Postby tbot » Mon Jun 27, 2011 9:14
Cooling/cleaning is the water part, Meth is the higher octane part. Run windshield washer fluid and you'll be fine.
Operator
Postby Operator » Tue Jun 28, 2011 9:14
I'd run the yellow bottle of HEET at a minimum. But look into just buying a 5 gallon jug. Its cheaper and you'll know for sure your w/m ratio.
JL 1000/1 - JL 450/4
[/font]
Current:
dsm_luck
Postby dsm_luck » Tue Jun 28, 2011 9:14
tbot wrote:Cooling/cleaning is the water part, Meth is the higher octane part. Run windshield washer fluid and you'll be fine.
Actually methanol contributes greatly to dropping BATs but water is better at dropping EGTs. Methanol has a high latent heat of vaporization and makes the boosted air cooler and more dense. I have found that a 65% methanol blend drops BATs more significantly than 27% windshield washer fluid.
dsm_luck
Operator wrote:I'd run the yellow bottle of HEET at a minimum. But look into just buying a 5 gallon jug. Its cheaper and you'll know for sure your w/m ratio.
I found a place that sells 5 gallon buckets for $20 in commerce city.
erod550 wrote:You can inject water/meth without a new tune. It just won't take advantage of the extra octane, so you won't see much of a power boost, if any. But you'll still have the cooling/cleaning effects.
I don't know if I totally agree with that. The cooling effect can be substantial. If you are spraying meth and bringing your 100 degree BATs down to 70 degrees there has to be a power bump there as well. Plus the expanding steam from the water creates more cylinder pressure and will increase TQ a slight bit. I am not using the octane benefits much. I spray 65% meth on a D05 nozzle with a tank of gas that consists of 33% E85 and I run 11.8 AFR. I will almost guarantee that my times at bandimere will be quicker than the last 13.8 and all I have done since then is add the methanol injection and am pushing a psi or so more boost with minor timing tweaks.
Postby erod550 » Wed Jun 29, 2011 9:14
dsm_luck wrote:I don't know if I totally agree with that. The cooling effect can be substantial. If you are spraying meth and bringing your 100 degree BATs down to 70 degrees there has to be a power bump there as well. Plus the expanding steam from the water creates more cylinder pressure and will increase TQ a slight bit. I am not using the octane benefits much. I spray 65% meth on a D05 nozzle with a tank of gas that consists of 33% E85 and I run 11.8 AFR. I will almost guarantee that my times at bandimere will be quicker than the last 13.8 and all I have done since then is add the methanol injection and am pushing a psi or so more boost with minor timing tweaks.
In general you get a 1% increase in horsepower for every 10 degrees you can lower the intake temp. So if you're putting down ~250whp, you'll gain 7-8whp from the intake charge cooling. I just meant you're not going to see a major bump in power just from injecting meth/water and not making any changes to your tune, but it sounds like you did modify your tune, so you are probably seeing more of an increase in power.
dsm_luck
Postby dsm_luck » Wed Jun 29, 2011 9:14
erod550 wrote:In general you get a 1% increase in horsepower for every 10 degrees you can lower the intake temp. So if you're putting down ~250whp, you'll gain 7-8whp from the intake charge cooling. I just meant you're not going to see a major bump in power just from injecting meth/water and not making any changes to your tune, but it sounds like you did modify your tune, so you are probably seeing more of an increase in power.
Yea that's true. I am working on a 12.2 AFR tune right now which should be cake with the methanol. After that its time to get some help with a more aggressive timing curve. I really don't think mid 13's is going to be out of the question.
Users browsing this forum: No registered users and 153 guests
