So.. We've pin-point the issue of my car. It's a electrical issue going on, but I don't know if it needs to be ALL replaced or just some of it. Eight months ago, Mazda said I had a electrical issue that needed to be fixed, but they wanted to charge me 3,000$ for it.
Does anyone or would anyone know (or are you one?) someone who's really good with Mazda's electrical system for the RX-7 that can assist and pin-point what's going on?
At this rate, my project car has come to a halt, while I fund up some money for a re-wire. If I can't get anyone to look at it, I have my friend Pat that can re-wire it all for 630$ (that's taking apart the interior and putting it back, vs just putting it back.).
At this time, if I could get anyone's help, it would be very much appreciated.
Car Electrical Issue...
christi
13B n/a Street Port
Goopy performance
2005 Mazda 3
nothin' but stock love.
13B n/a Street Port
Goopy performance
2005 Mazda 3
Well, I am not sure why you would need a re-wire. At worst, a new engine harness is maybe $200 for a decent NA harness, and NA harnesses have not nearly the issues the T2 harnesses did.
Before you go making plans, as I have said all along, make sure you get an accurate diagnosis of what the specific issue is. Also be very careful who you take advice from regarding electrical issues as there are a lot of internet myths out there. I will have more time than is currently available to me in the next couple of weeks if you still need help.
christi
Dommo I wanted a second opinion before doing anything else. Sorry, meant to say that we *think* we have it.
Whenever the car was driving it drove fine, but soon as the rpm tac quit working It would drive like crap. I've changed one of the coils already, when secondgenpat looked at my car...he said only one was bad.
13B n/a Street Port
Goopy performance
2005 Mazda 3
13B n/a Street Port
Goopy performance
2005 Mazda 3
ithere is still something wrong with the coils.(iirc) The taco-meter works of the coils so when the coils stop working properly it will affect the taco-meter.
christi
So how does one test it? I purchased the leading coil from Don. Honestly I really don't know what else to do. This is way beyond me.
13B n/a Street Port
Goopy performance
2005 Mazda 3
13B n/a Street Port
Goopy performance
2005 Mazda 3
actually the taco-meter works offa the percentage of Tac Bell Tacos one has at 2am...
I would have to look but IIRC the tach signal for an S5 comes from the ECU, not the coils directly. You could be having a CAS issue, or possibly a ground issue (lots of ground issues with these cars) or some other problem actually inside the ECU. I do not believe I have an S5 NA ecu here, but I will poke through the box of ECU's I have here and see what I have.
christi
yeah. That's why I'm looking for someone who would be interested and is good enough to diagnosed. I've got no way to bring her to Denver. She still needs to be timed, but she barely starts, if at all half the time, but when she does.. she *does* idle.
Edit
She's loud. She sounds healthy ish but she is misfiring. This is when we got her running before taking her for a drive when the tach stopped.
http://m.flickr.com/photos/frogmeow/5825648370/
Sent frommy iPhone.
Edit
Sent frommy iPhone.
13B n/a Street Port
Goopy performance
2005 Mazda 3
13B n/a Street Port
Goopy performance
2005 Mazda 3
D Walker wrote:actually the taco-meter works offa the percentage of Tac Bell Tacos one has at 2am...
even though it does not get signal from the coil directly, if the tach does not work then the leading coil does not work. i know this by experience and icemark from 7club. if it were an ecu problem it wont idle at all no matter what you do.
it might be a grounding issue but i doubt it. also its not a cas issue. im pretty certain that its a timing issue just by the way its running and by zico. by what i was told the timing on the cas was waaaaaaaaay off. so i suggest a timing light and setting it back to stock timing.
edit: oh yea replace that leading coil!!!
