Does anyone have this??
Coulda
Postby Coulda » Fri Jun 03, 2011 9:14
No real reason to replace behind the downpipe unless your trying to change the exhaust note...you get so little power its not worth it. I would just do the DP.
Speed3
Postby Speed3 » Fri Jun 03, 2011 9:14
Coulda wrote:No real reason to replace behind the downpipe unless your trying to change the exhaust note...you get so little power its not worth it. I would just do the DP.
Will downpipe alone make it a lot louder?
2007 Mazdaspeed 3
Coulda
No because you will still have the stock second cat and muffler. In order to have a chance at passing an emissions test ull need a catted downpipe too.
Speed3
Coulda wrote:No because you will still have the stock second cat and muffler. In order to have a chance at passing an emissions test ull need a catted downpipe too.
When would I have to take an emissions test?
2007 Mazdaspeed 3
Coulda
I live in Aurora...we have to do one anually so I just assumed it was a statewide thing...if you dont have to comply with emissions than thats all the better...one less thing to worry about :-)
Speed3
Postby Speed3 » Sat Jun 04, 2011 9:14
Coulda wrote:I live in Aurora...we have to do one anually so I just assumed it was a statewide thing...if you dont have to comply with emissions than thats all the better...one less thing to worry about :-)
I've never had to lol but I want a catless downpipe for sure. I just want a sound that is loud enough so people hear me and it turns heads but to where I can still have a conversation inside lol what would be the best option
2007 Mazdaspeed 3
Postby erod550 » Sat Jun 04, 2011 9:14
Pretty much any of the catbacks out there will allow you to do that as long as you don't get them without resonators and/or mufflers. I had the CP-E catless downpipe and a CP-E catback with no resonators or muffler and it was just ridiculously loud and not in a good way. But with 1 muffler and 1 resonator it would have been perfect.
And just remember that when you buy a downpipe you really should get an AP too or you will run into problems like boost cut.
Speed3
erod550 wrote:Pretty much any of the catbacks out there will allow you to do that as long as you don't get them without resonators and/or mufflers. I had the CP-E catless downpipe and a CP-E catback with no resonators or muffler and it was just ridiculously loud and not in a good way. But with 1 muffler and 1 resonator it would have been perfect.
So catless downpipe with stock cbe will be about as loud as an aftermarket cbe? It seems like a downpipe is going to start costing me a lot of money..
2007 Mazdaspeed 3
No, it won't be as loud. The stock CBE will quiet it down quite a bit. I really liked how my car sounded with stock downpipe and CP-E straight through CBE. It was just way too loud and didn't even sound good once I put the catless downpipe on, so I went back to the stock CBE and it sounded good but it was a little too quiet for me. I was going to look into getting another CBE this summer but then I bought the Mustang instead.
And yea once you start doing downpipe, AP, upgraded intercooler, fuel pump, etc. it starts adding up. Next thing you know you've got 3k into the car. But it is so worth it imo, hehe. The car fully bolted is way more fun to drive and will surprise a lot of cars.
Speed3
erod550 wrote:No, it won't be as loud. The stock CBE will quiet it down quite a bit. I really liked how my car sounded with stock downpipe and CP-E straight through CBE. It was just way too loud and didn't even sound good once I put the catless downpipe on, so I went back to the stock CBE and it sounded good but it was a little too quiet for me. I was going to look into getting another CBE this summer but then I bought the Mustang instead.
Well i'm stuck then ha cuz I want more power but a better sound too so i'll have to do some reconsidering lol plus idk how that AP works :/ sound complicated to me.. this is the first time i've really gotten interested in modding a car..
2007 Mazdaspeed 3
The AP is really easy to use. You plug it in, scroll through a few menu options, and it does the rest. And catless downpipe with stock CBE will still sound better than stock downpipe with stock CBE. So there will definitely be an improvement in sound along with a big improvement in power. It just won't be really loud. If you want power, I'd do the downpipe first and see how you like the sound, then you can always get a CBE later on.
Speed3
erod550 wrote:The AP is really easy to use. You plug it in, scroll through a few menu options, and it does the rest. And catless downpipe with stock CBE will still sound better than stock downpipe with stock CBE. So there will definitely be an improvement in sound along with a big improvement in power. It just won't be really loud. If you want power, I'd do the downpipe first and see how you like the sound, then you can always get a CBE later on.
Thanks good advice there! But what are the pros/cons (if any) of the AP if I had just a CAI and the downpipe..
2007 Mazdaspeed 3
The AP will add more power and will eliminate the boost cut you will run into with a downpipe. The downpipe reduces restriction on the exhaust side of the turbo. This effectively raises the boost as the turbo is able to spool more easily. The ECU sees the increase in boost and freaks out, thinking something is wrong, and cuts power. At this time, you're full WOT and not expecting it and your face hits the steering wheel, lol. The AP raises the limits for the ECU freaking out and cutting power, plus gives you more power just from having a tune and leaning things out because the stock tune is crazy rich at high RPMs and also closes the throttle on you as the RPMs climb. Also the AP gives you the ability to datalog so you can see what is happening with your car. It really is a fantastic device.
Speed3
erod550 wrote:The AP will add more power and will eliminate the boost cut you will run into with a downpipe. The downpipe reduces restriction on the exhaust side of the turbo. This effectively raises the boost as the turbo is able to spool more easily. The ECU sees the increase in boost and freaks out, thinking something is wrong, and cuts power. At this time, you're full WOT and not expecting it and your face hits the steering wheel, lol. The AP raises the limits for the ECU freaking out and cutting power, plus gives you more power just from having a tune and leaning things out because the stock tune is crazy rich at high RPMs and also closes the throttle on you as the RPMs climb. Also the AP gives you the ability to datalog so you can see what is happening with your car. It really is a fantastic device.
Damn that really does sound awesome! So this is considered a tune right? Cuz I've never tuned a car or anything like that so idk how that works.
2007 Mazdaspeed 3
Yes. You can load what are called OTS (off the shelf) tunes that are general tunes based on which intake you have. They do a decent job. Eventually you'll want to get a dyno tune so you have a tune that is specific to your car. That's even more money though, heh.
