AutoTech Internals ordered!!
- DISIindaHead
Ordered them yesterday. There was no way I was going to pay almost 700$ for a damn fuel pump. Also ordering the CNT catted downpipe tomorrow and then it'll time to run Stage 2..hopefully everything arrives within the next 2 weeks. I will keep you guys updated as far as install, maybe include some pics as well. Stay tuned
Just a heads up but if u run an OTS map you are going to be running 4psi or so under targeted boost levels. I was peaking at 15 psi with a stage 2+ fmic map. Had to use ATR to up the load and WGDC to get it to hit 18 psi. Not sure if you know this or not. Altitude seems to have a significant effect on how much boost the ecu pushes.
- DISIindaHead
hmm I'll have to keep that in mind. Once the mods are installed ill definitely post up some logs. Thanks for the info.
[color="Silver"]2010 Mazdaspeed 3 Sport (Tech Package)[/color]
[color="Black"]
GTX3071r :: 30/70 E85 Mix :: ATP TIP:: ATP 3" MAF :: Turbosmart BPV :: Grimmspeed EBCS :: COBB AP :: Full Race Mani :: CNT Racing Catted DP :: Corksport Exhaust :: JBR Trilogy Mounts (88 duro) :: JBR SS bushings :: KSport Kontrol Pro Coilovers :: DDM 8000k HIDs :: Luminics JDM Yellow foglight bulbs :: Corksport interior LED conversion :: Corksport TMIC :: Matt Damon OCC:: ProSport Boost Gauge w/ Vent Pod :: Denso ITV22s :: Autotech FP Internals[/color]
[color="Black"]
- reconbygod12
- DISIindaHead
hoping for the best. I've read most last around 10,000 miles, hopefully by then the price of the CP-E pump will drop.
[color="Black"]
[color="Black"]
Users browsing this forum: No registered users and 210 guests
