Issue with a tire
Postby Learjet45 » Sun May 22, 2011 9:14
Crap, 35 was a typo. It was at 45 when I started letting air out.
Come to think of it, I could leave the tire off and just bring it over, but at the same time I don't have a jack stand. Just the jack. I'll play it by ear :p
And skip the first h :p (Jonathan)
Postby I`m Batman » Mon May 23, 2011 9:14
I have 3 of these... one for each of my cars.
[ame="http://www.amazon.com/Interdynamics-TX-300-TyphoonMax-12-Volt-Compressor/dp/B000VZHJFI"]Amazon.com: Interdynamics TX-300 TyphoonMax 12-Volt High Speed Air Compressor: Automotive[/ame]
You might not think it's worth it now but when you NEED it, it's totally worth it.
My wife's car has a full size spare that's never been used... until one day it needed to be used and guess what? No air in the tire. Good thing I had this in the car.
Plus, when I needed air in my tire at home (or work, or where ever I am), I don't need to fire up my big compressor, I just plug this little guy in. It's totally worth every penny IMO.
Postby dommo_g » Mon May 23, 2011 9:14
Learjet45 wrote:Well excuse me for not knowing the exact technical term being that I haven't even been driving on my own for a year yet. Not to mention that even if I knew the proper term, I wouldn't have been sure if that was the issue.
No, I don't have any way to fill the tire at home.
And I'd rather just stick the spare on and take it to Firestone and tell them to fix it instead of trying to put 50psi of air in it to see whether that fixes it or not.
Point is, your valve core (the little thing on the tire that you press in to let the air out) is stuck, or the seat is bad. If it's just stuck, a shot of high pressure may force it to pop back out. If the seat on the core is shot, you'll have to remove the whole thing anyway. I was trying to give you a way to avoid removing the tire from the car.
Did you ever get this figured out?
Postby erod550 » Mon May 23, 2011 9:14
I`m Batman wrote:I have 3 of these... one for each of my cars.
I might have to get one of those just for like you said, small jobs at home to just add a couple psi to a low tire without having to drag out the big compressor. Hmm...
Postby Learjet45 » Mon May 23, 2011 9:14
Turns out the entire TPMS sensor needs replacing including the valve. McDonald is taking care of it.
That sucks. High dollar piece right there.
At least they are taking care of it. Firestone wanted $165 for the part and even suggested bringing it back to McDonald to try to get them to fix it since we've only had the car for 2 days.
alex_n/a
Postby alex_n/a » Mon May 23, 2011 9:14
technollogy sucks. That's one reason I don't have a new car. I really don't want to deal with electronics in my tires. :D
the other reason is I'm a broke mofo :lol:
Postby iani1.1 » Mon May 23, 2011 9:14
agreed electronics suck ***. i like doing things manually...
Learjet45 wrote:At least they are taking care of it. Firestone wanted $165 for the part and even suggested bringing it back to McDonald to try to get them to fix it since we've only had the car for 2 days.
So this is a different car from the 6?
Yes. I got a 2008 Subaru Legacy on Saturday to replace my dying 6.
Justin
Postby Justin » Mon May 23, 2011 9:14
You may just be able to loosen it up by putting a little air in it. I'd be tempted to try with a bicycle pump, not that its likely to help.
McDonald replaced the TPMS sensor and we got the car back. I guess the sensor in the car still has to be reset and until then the TPMS light on the dash is going to stay on, but it's not that big of a deal. Just going to have it taken care of when we do an oil change.
Users browsing this forum: Google [Bot] and 127 guests
