AP Datalogs
Originalguy
AP Datalogs
Postby Originalguy » Mon May 02, 2011 9:14
so i got my ap recently and i married it to my car. i loaded the stock map on it cause i have my standback still plugged in and my tune is on that but i was doing some datalogging and i love that dyno feature. granted it isnt very accurate but these numbers are awesome with my car set at 3999 pounds and running from 3k to 6200 rpm in 4th gear
[ATTACH]1812[/ATTACH]
not bad eh? too bad its not 100% accurate
Mazdaspeed FTW
Postby ~Barn~ » Mon May 02, 2011 9:14
I've always wanted to try that on my AP, but never have. Where did you get the weight figure, out of curiousity?
Image 720.935.6438
Postby chickenwafer » Tue May 03, 2011 9:14
When I had the AP on my RX-8 I could do back to back "dyno" runs with the same weight entered, same rpm pull, same everything is get variations of up to 250whp. It's a gimmick.
The best "performance metering" of the AP is the 0-60mph and 1/4 mile meters because it's a set and forget type of feature, no messing around, just come to a stop and launch and it lets you know how fast you are. Pretty nice features, I used it to compare my 0-60mph times when my RX-8 was NA and then turbo.
Originalguy
Postby Originalguy » Tue May 03, 2011 9:14
yeah i know its a fun toy but there are too many variables like i turned my weight up to like 4800lb then went down a steep hill at full throttle and it showed like 721hp i was like wow so i guess everything has to be just right for it to read remotely accurate. and i figured if the ms6 has a curb weight of about 3600lb (iirc) plus my 160ish plus my two twelve inch subs and box plus the two rotors and rotor housing plates i had from an old 13b in the trunk i figured 4000 was a reasonable guess
Mazdaspeed FTW
reconbygod12
Postby reconbygod12 » Wed May 04, 2011 9:14
i thought that was for at the crank hp though becasue on mine i read way higher then what my whp was on both the inerita dyno and then also macs dyno
2008 wrx sedan-new love
09 cwp mazdaspeed 3 GT-gone
04 mazda 6s-gone
Originalguy
Postby Originalguy » Thu May 05, 2011 9:14
im not sure what it is specifically or how it works exactly all i know is that its massively inaccurate but fun to play with
Mazdaspeed FTW
Regulator
Postby Regulator » Thu May 05, 2011 9:14
chickenwafer wrote:When I had the AP on my RX-8 I could do back to back "dyno" runs with the same weight entered, same rpm pull, same everything is get variations of up to 250whp. It's a gimmick.
Aww man you can't go telling us that and then not give us the numbers! Spill it
