FC Rotory Help
Postby RX-7 Chris » Mon Apr 25, 2011 9:14
I bet the fuel filter does have a bunch to do with it, I didn't realise it hasn't been changed. That's usually one of the first things I do when I get a used car.
Christi, I had told you about the broken intake air temp sensor and said it was probably causing the CEL.
ecam8000
Postby ecam8000 » Mon Apr 25, 2011 9:14
Pat was meticulous and well equipped! He did all the work on Christi's RX7. I just stood around with my hands in my pockets and watched (just like Christi). Thanks for helping out Pat. My candidate for new guy on the CMZC who jumps in and helps award.....of the year......prize.
And for most likely to not bring I/C when he said he would and then forgot.....:rolleyes:
Eric
2 Fords 29 & 2000.
99 BMW 328i
THANKS! To all who serve.
Postby Learjet45 » Mon Apr 25, 2011 9:14
Well it would have melted anyways :p I'll bring some next time lol.
ecam8000
I wasn't going to mention names......
Eric
2 Fords 29 & 2000.
99 BMW 328i
christi
Postby christi » Mon Apr 25, 2011 9:14
Jon does a good one revealing himself haha.
Chris- yes. That's how pat found out. I told him
About the disconnect wire. He texted me last night and found his parts from his S5 for the thermo sensors. Yay!
Well stopping by while on the beach! Haha thanks again Pat for looking after her ;)
13B n/a Street Port
Goopy performance
2005 Mazda 3
nothin' but stock love.
SecondGenPAt
Postby SecondGenPAt » Mon Apr 25, 2011 9:14
Tonight after work I had some time to look into things. changed the fuel filter (it was the original one Christi) that made a huge difference. No more hunting idle. then i smoke checked the intake. found 3 (possibly more) vacuum leaks. 2 were from the secondary butterfly valve shaft seals (each side) the backside I was able to fix with RTV on the thermopelet for fast idle cam. the front one all I could do was smear hylomar on and hope for the best. The 3rd (4th, 5th, etc) is from under the LIM, so I'll need to remove that to find the rest. (get rid of all un-necessary engine components as well) :D
That will probably happen Saturday.
I also found an E-fan off of an Ford Taurus SHO that almost covers the radiator. I am going to try to install that tomorrow if I have time. Temp needle is still staying at the halfway mark at this altitude so no worries yet.
Cliffnotes:
-changed fuel filter
-repaired 2 vacuum leaks
-found other vacuum leaks
Vehicle now idles at 450-ish. low, but steady.
Woo! I would totally come help if I knew anything about rotaries. If you need an extra set of hands to help with something let me know and I can try my best to come help!
alex_n/a
Postby alex_n/a » Mon Apr 25, 2011 9:14
I may be able to help you out saturday, I am mechanically inclined but not a rotary guru although I would like to. I'll post later on this week after I check my schedule.
SecondGenPAt
Postby SecondGenPAt » Thu Apr 28, 2011 9:14
ugh, So tonight I found out that the leading igniter is DOA.
**If anyone has a spare leading coil igniter please contact me. (don't absolutely need the coil, just module the coil is mounted to)
other news:
fixed the oil leak from the filter pedestal (and did the oil change Christi :D )
advanced the timing to bump idle to 550-ish
prepped for unnecessary engine part removal on sat.
christi
Postby christi » Thu Apr 28, 2011 9:14
Yeah Mazda said that I needed to replace that too...is it a easy part to find/replace?
Don't forget about me Saturday night haha :P
13B n/a Street Port
Goopy performance
2005 Mazda 3
SecondGenPAt
I have my buddies back home shipping one out, but if I can find one sooner, we can have you running strong this weekend.
and what is this about saturday???? :D
Postby Learjet45 » Thu Apr 28, 2011 9:14
Quick! Sell the car on ebay before she gets back!
christi
SecondGenPAt wrote:I have my buddies back home shipping one out, but if I can find one sooner, we can have you running strong this weekend.
!! Picking me up satitdaywhat you think!
13B n/a Street Port
Goopy performance
2005 Mazda 3
Postby RX-7 Chris » Fri Apr 29, 2011 9:14
christi wrote:Yeah Mazda said that I needed to replace that too...is it a easy part to find/replace?
Did you just forget to tell everyone about the leading igniter? That could be causing most of your problems.
christi
Postby christi » Fri Apr 29, 2011 9:14
I guess I did....I JUST remembered!
Also, I think Eric and Zico knew cause they had/read the notes that Mazda put down but ever so long ago.
13B n/a Street Port
Goopy performance
2005 Mazda 3
Users browsing this forum: No registered users and 103 guests
