limp mode
- reconbygod12
limp mode
so my car doesnt go over 4500 rpms and only has 14psi so i was wondering if anyone has had tohught that possibly my car went into limp mode for some reason? i dont have KR either so i was wondering also is it possible my fuel pump just is gong out as well
2008 wrx sedan-new love
09 cwp mazdaspeed 3 GT-gone
04 mazda 6s-gone
04 mazda 6s-gone
Are you monitoring your DI fuel pressure with the Dashhawk? That will tell you if it's a fuel pump issue. Kind of unlikely that a dying fuel pump would limit the car to 4500rpm. It would just cut out when the pump was stressed, not at a specific rpm.
Have you rest your ECU by pulling the negative battery cable for a couple minutes? Any CEL? Any codes that the Dashhawk can see?
If that doesn't work you might try reflashing your map as that almost sounds like Valet mode.
- reconbygod12
- reconbygod12
Not likely. I would just try reflashing your tune again. See what happens then.
- reconbygod12
- *MS3~SNAIL*
Have a SRI on it?
2010 MazdaSpeed3 Black Mica | Cobb AP | CS SRI/TIP [color=black]| CS Racepipe [/color]| CP-E 75 Duro RMM | 30% Tint all around [color=#000000]| Blacked out fog light trim and emblems [/color]| Radar detector tapped into HomeLink/Compass RVM | WeatherTech Floor Mats Front and Back | Fumoto Oil Drain Valve
[color=blue]:D The sportos, the motorheads, geeks, sluts, bloods, waistoids, dweebies, dickheads - they all adore him. They think he's a righteous dude.
[/color]
[/color]Will it go above 4500rpm free-revving while stopped? Or without much load on the car? Or is it only stopping you at 4500rpm when you are WOT?
- reconbygod12
*MS3~SNAIL* wrote:Have a SRI on it?
i am fully bolted on the car well over 10k on the car
and eric my car in 1st gear wont go over 4500 and when i shift to 2nd it will but it struggles to go over that if i am in wot or driving regular it will not go over 4500 rpms i dont think that my launch control ****ed my ecu yuyp though because tahts what my launch control is set up as well though
04 mazda 6s-gone
04 mazda 6s-gone
I bet you anything the VSL (vehicle speed limiter) is messed up in your launch control settings. Your VSL should be like 12. If you have it too high, it won't turn off the lower rev limiter until you get above the MPH you have set for your VSL. So if you never get to that speed, it will keep you under that rpm indefinitely.
Try just changing your settings to these in ATR and reflashing and seeing what happens.
FFS Rev Limit: 5300
LC Rev limit: 2800
VSL: 10 (mph)
FFS Rev Limit: 5300
LC Rev limit: 2800
VSL: 10 (mph)
- reconbygod12
Did you just play with the launch control settings? This doesn't actually have anything to do with the tune itself. It's a launch control thing.
- reconbygod12
Users browsing this forum: No registered users and 129 guests
