ian's all show no go build
Postby speedjunkie » Fri Apr 15, 2011 9:14
Not too bad! I see you didn't mask off the steering shaft when you painted the subframe LOL.
Postby iani1.1 » Fri Apr 15, 2011 9:14
haha i found green engine enamel and that happened. i pretty much said **** it and started spraying LOL
Postby iani1.1 » Sat Apr 16, 2011 9:14
getting the engine in this morning was a bitch but anyways got it in finally lol
i do need a new oil cooler since i didnt take off the one that was attached it got pretty banged up during the swap process. i might as well go with a dual cooler setup just cause it looks cool LOL
i just finished doing the power harness. i could use some green tape to make it look a little better. also this is probably the only time i will ever redo wiring harness.
Dumbizzle
Postby Dumbizzle » Sun Apr 17, 2011 9:14
looks good did you get it running yet
Postby iani1.1 » Sun Apr 17, 2011 9:14
thanks, i still have a ways to go to get it running. i have yet to finish up the body harness, wire up the megasquirt and still waiting for some parts to get here.
Postby chickenwafer » Sun Apr 17, 2011 9:14
That harness looks neon green!
yup its green alright. its this stuff
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=360092464536&viewitem=&sspagename=STRK%3AMEWNX%3AIT#ht_500wt_956
its a little too small but it stretches which is pretty cool
Dumbizzle
dang thats cool what size would you recommend getting if the size you got was a little small
anything 1in or bigger in diameter should be alright. since im seperating each connector from each other all i needed was the 3/8 but i ended up buying 75ft worth lol
Postby iani1.1 » Sun May 08, 2011 9:14
didnt feel like doing wiring today so i did this instead.
though this is what i have left to wrap
new wider rear fenders and free aero lol
Postby speedjunkie » Sun May 08, 2011 9:14
Free aero? Did you find them tossed by the garbage or is that Kevin's old bumper or something? It looks kinda familiar lol.
How much wider are the new fenders? Is it just the rears or fronts too?
Postby iani1.1 » Mon May 09, 2011 9:14
yea kevins old skirts and bumpers. needs some work though. the rears are 30mm dmax and im getting 25mm dmax fronts. or maybe 30mm forsight fronts havent decided yet
Postby RX-7 Chris » Mon May 09, 2011 9:14
Why not go full wide body now and save yourself the trouble? Everytime we see your car it's wider so you might as well go all the way.
Postby iani1.1 » Sun May 22, 2011 9:14
soo i got the car started and kinda running... then decided to take it apart again LOL
i still need a few more things to make it roadworhy but it runs pretty alright. loud as **** without a downpipe. also got a new/used diff today ill be installing that tomorrow. depending when i get off work.
Users browsing this forum: No registered users and 107 guests
