Hey guys, long time no see, haha. All the RX-7s at the drift event last weekend motivated me to get some work done on my FD. One of the biggest things I want to do is replace all the worn out suspension bushings. This means front and rear control arms, trailing arms, and the rear differential mount (which I think requires dropping the subframe). Does anyone here work at a shop with a press and/or have the tools to do this? I will pay you, I just want to get it done ASAP. Thanks in advance!
P.S. - Here's a good writeup on RX-7 club, so you have an idea of how big of a job this is...
http://www.rx7club.com/showthread.php?t=648765
FD suspension bushing install
It's a big job but do-able at home, unless you just don't want to do it (I don't either). You can pick up a decent press at Harbor Freight for under $100 bucks and it basically pays for itself after your first bushing job.
I haven't done it yet, but I'm pretty positive replacing the rear diff bushings doesn't require dropping the subframe. You don't even have to drop the diff completely. It's a messy and labor intensive job, however.
I plan on doing mine soon as well. I think I'm going with the Powerflex bushing kit and getting Rotary Performance solid diff bushings and a Banzai diff brace to really tighten up the rear end.
Remember you will need an alignment ASAP after replacing all the bushings!
^Just to add, I can confirm you can get the diff mount out without dropping the subframe. Just remove your catback, the aluminum and plastic splash guards, the aluminum PPF brace, jack up the diff and remove the two bolts, then slowly lower it.
With the axles still into the diff it isn't going anywhere and it will provide enough clearance to access the 4 bolts holding the diff mount (which holds the bushings) for removal.
Sweet, good to know about the diff. I didn't realize presses were that cheap, maybe I'll just do it myself. But yeah, I don't want to do it, I don't like working on cars all that much, unless I have help. If you're interested in doing it eventually and want to help out, we can let my car be the guinea pig
I used a vise and different sized sockets to do mine, but Simon used a press and he still has it in our garage. It's kind of a pain, but not too bad. Just takes time.
Furthermore, I removed my diff mount bracket without removing the diff, but it was a YATCH getting the bolts on top loose. I finally got them though. Those were also the hardest bushings to install.
chickenwafer wrote:A "Yatch"? LOL! I can't imagine it's fun, coupled with an already tedious bearing job.
Eric, what bushing kit did you get? Did it replace the factory pillow ball bushings with polyurethane or no? Because all 6 factory pillow balls are around $450 bucks, on top of a $680 bushing kit.
Yatch as in "Beeyatch" lol. I didn't feel like getting ****** for the word I was typing but I still wanted to get the point across haha.
I got the SuperPro kit, but it was during a group buy so it was a bit cheaper, like $580 or something I believe for the full 24 piece kit. No, I don't think there is a company out there that replaces the pillowballs. I bought those from Ray Crowe at Malloy Mazda so those are new as well. You know he gives us a discount right?
