Volvo Fun, my '01 V70
Just to continue my running maintenance thread, finished an oil change (ran Seafoam through the crankcase for about 100 miles prior). Used Mobil 1 5W30 picked up from Costco. Replaced the thermostat as well.
I was driving around yesterday and started to get nervous. Other than a needed alignment/balance, the car is running very smoothly. Which got me thinking, every car I've owned had run the best, right before it blew up.
Decided before I did the rear brakes, I'd go ahead and replace the parking brake shoes as well. Car has almost 150k on it and I'm sure never been done. $20 in parts, so why not. Beats pulling off the old rotors and seeing little parking brake shoe bits and pieces. I'm going to paint the hats on the rotor too since I'm not a big fan of the "rust" look after they've been on the car a while. Not sure when I'll actually be getting it done, as I'm getting quite the stockpile of parts.
Ah, maintenance. I want to be doing fun stuff, damnit!
Finally tossed the new pads, rotors (caps painted black), parking brake guts (the parking brakes are drums on the car, so new shoes/springs), new rear end links and I'm all out of my parts stockpile. Now, to figure out what to deal with next. I need rear shocks...so that'll probably be the road I travel next.
This weekend, swapped over some gauges from my brother-in-law's XC90. He had an instrument panel circuit board go bad, so he replaced it. So I scavenged the front panel, gauges, and aluminum trim rings from his old instrument panel and put them in my car, which basically updates it to an 05+ panel. Wee. I think it looks better, and it was free. Eventually, I'll take some pictures of it.
need to see pics already.
Ordered the ball joints and control arms. Also need to go ahead and order inner/outer tie rods while I'm at it, as those are under $100 total. My plan was to do all of the suspension bits at the same time, but I'm going to wait to do the springs/struts/shocks/sways, as that'll add quite an expense.
With that, I'll finally be installing my S60R downpipe, and a few other bits laying around.
Stupid high mileage cars. I don't wanna be rebuilding the front end, I wanna do fun stuff!
I know how that goes. Good luck.
Users browsing this forum: Baidu [Spider] and 51 guests
