First Gen RX-7 Part Out
Postby RX-7 Chris » Mon Dec 20, 2010 9:14
shutter was not sold
seats and springs are sold.
Rear brakes are pending
Postby RX-7 Chris » Wed Jan 05, 2011 9:14
Updated List:
I've removed some parts that are gone, added others, and clarified some.
All prices do not include shipping and are negotiable. I can post more details and pictures if requested.
-85 GSL Rear (one of the axles is stuck in the housing) $75
-+ wheels with almost new Sumitomo HTR 200 (5k on them) - $230 (4) pickup only
-Center console painted black - $10
-Storage bin lids 84-85 grey - $10 (2)
-Hood - $20 pickup only
-Cowl cover 84-85 - $15
-Glove compartment with painted black lid - $10
-Cooling fan with clutch - $15
-Door glass - $50 pr (have a few sets)
-air filter assembly (holes plugged with silicone) - $20
-new shutter valve still in box from Mazdatrix - $50
-partial wiring harness for '83 (was cut at firewall so everything from firewall back) - $30
-81-83 stereo panel (great shape) - $50
-79-83 grey dash cover - $10
-81-83 pocket under radio - $5
-81-83 column cover set - $20 (2 sets)
-81-83 GSL emblems – 15 pr (3 pr)
-84-85 GS change holder brown tabs broken (where power window switches would be on GSL) - $5
-maroon sun visors missing mounting tabs - $10 (2)
-81-83 LCD clock working - $20
-81-83 headlight lift switch - $8
-81-83 rear defrost switch - $8
-81-83 power window switches, CC switch, rear wiper switch, and switch plate (light out in CC switch) - $40
-84-85 12A computer - $30
-81-85 12A choke with slightly frayed cable and good knob - $40
-81-83 front hubs with rotors, calipers, hardware, bearings, and caliper brackets - $150 (for both sides)
-81-85 amber side marker set - $20
-maroon parking brake cover - $5
-83 air control valve - $40
-black door sills pr - $30
Postby iani1.1 » Wed Jan 05, 2011 9:14
hm, i might want that gsl rear since i am buying zico's fb. wheels and tires as well.
do you by any chance have the fan shroud? i dont wanna have to pull it out at u pull and pay... yes im that lazy lol
iani1.1 wrote:hm, i might want that gsl rear since i am buying zico's fb. wheels and tires as well.
I do have the fan shroud sitting in the garage
Postby RX-7 Chris » Fri Jan 28, 2011 9:14
GSL Rear is sold
Postby RX-7 Chris » Thu Feb 10, 2011 9:14
Updated List:
-81-83 front hubs with rotors, calipers, hardware, bearings, and caliper brackets - $125 (for both sides)
I should have some more parts added to the list soon.
Postby RX-7 Chris » Sun Mar 06, 2011 9:14
Updated List:
-81-83 GSL emblems – 15 pr (2 pr)
-81-83 rear hatch opener switch - $8
-81-83 fuel door opener switch - $8
-rear hatch opener - $20
-fuel door opener - $15
-74-85 MAGNECOR 8.5MM SPARK PLUG WIRE SET (sells for $60 new) lightly used - $30
I added a few things to the end of the list and I have more parts to come soon.
Postby RX-7 Chris » Wed Mar 23, 2011 9:14
grey sunroof hand crank assembly - $25
I have a second one that looks the same.
Postby iani1.1 » Wed Mar 23, 2011 9:14
i need to get that hood and driver side headlight motor.
I need to get the motor pulled still. You should already have the headlight motor. I sold it to zico a while back.
oh thats the one? lol
well i can give you my hood and give you cash for yours. i dont have room to store the old one anyway
Postby RX-7 Chris » Fri May 06, 2011 9:14
I have a bunch more parts to add to this.
Postby RX-7 Chris » Tue May 10, 2011 9:14
I figured I'd get some pics of the Wheels and tires uploaded.
This is what the finish on all the wheels looks like:
All the wheels have curb rash and need to be refinished but none are bent in any way.
This is what the tire tread looks like on all the wheels:
I payed over $300 for the tires alone installed and balanced so $230 is a gread deal considering they are basically new. These are great tires, I wish they made them for my new wheels.
JerinX
Postby JerinX » Wed May 11, 2011 9:14
Those look saucy. I'll be seeing you on Saturday for those.
Similarly, if you put a more updated list I'll probably come bearing some extra cash to take some extra stuff. I'm eyeing the rear hatch switch/button - is it interchangeable with the 85s?
Will
1985 12A RX-7 (Fixer-Upper...FOR NOW!)
