So on Thursday I picked up a 92 Miata. 130,000 miles. Only 2 adult owners. It was fully loaded with all the options from the factory in 92 including power windows, cruise, power antenna. Even has a factory hardtop that it came with from the factory. The ONLY aftermarket equipment is a full Aerodyne turbo setup with a intercooler and full gauges along with Borla exhaust. This was apparently installed in the mid 90's.
The big question is, what does it need, right? Well, it threw a rod and put it through the oil pan. I have a 92 engine in my garage that was waiting for a project, so it looks like I have my work cut out for me! Will also see a new clutch and likely an aluminum flywheel. Otherwise, it will remain a total sleeper.
Pics to follow of the entire ordeal!
