No I don't drive a MS6, but figured you guys knowledge on AWD systems could help.
Just trying to get all the right info before I make a purchase:
Wheels are -
Front: 19x8.5 offset of 32mm
Rear: 19x9.5 offset of 35mm
Is anything under 1% diameter difference legit? I'm looking at 235/35R19 in the front and 265/30R19 in the rear which is a 0.87% difference. But moving to a 275/30R19 is only a 0.08% difference. I used http://www.1010tires.com/TireSizeCalculator.asp And I'm AWD. Thank you for any assistance.
MazdaSpeed6 guys chime in. Staggered Setup.
JL 1000/1 - JL 450/4 [/font]
Current:
Current:
I would advise against it. Speaking generally, all-wheel drive systems are happiest with the diameters are analogues. If not, you obviously have front and rear axles spinning at different rates.
You're talking about a pretty small difference in overall rolling diameter, but if it was me, I wouldn't risk it. Just pick up 4 of the same size wheels and tires. You can alter offset front/rear and it's not a problem, if fitment is a concern.
It's just the conave look of the 9.5's is what I'm after. And 9.5's in the front will be a tad hard to pull off.
Current:
Current:
OCD wrote:ive never heard of anybody pulling off 9.5's
not saying it cant or hasnt happen. and 19's to boot..
Just to clarify, I'm in an Audi A4. I was asking the MS6 crowd (or anyone that wants to chime in really) since I knew they were AWD too.
Current:
Current:
.08% is nuthin. You could get that difference between front and rear after driving 1000 miles the way most of us drive.
Operator wrote:No I don't drive a MS6, but figured you guys knowledge on AWD systems could help.
Wheels are -
Not in my bolt pattern. But from most of my findings, since I'm not dropped on coils I won't be as low as those that have run into problems. But that leads me to wondering how the set-up will look with my 1.4" drop.
Current:
Current:
Users browsing this forum: No registered users and 24 guests
