making a custom intake for my rx7
alex_n/a
Postby alex_n/a » Sun Feb 20, 2011 9:14
I hate the plastic intake on my fc, it's not really black anymore. I'll be replacing from the throttle body and running it in front of the radiator.
I need help though :huh: I keep searching up and down for a flange to replace the plastic elbow, but can't find one. So does anyone know how I can make one. or where I can get one made.
and I might need help with welding depending if I don't like using multiple silicone connectors. (free food/drinks for helping)
I got intercooler piping from Karl (msp superstreet) over the weekend and I'll be using this.
christi
Postby christi » Sun Feb 20, 2011 9:14
Good luck! I'd love to steal your idea (sort of) if you do the project :)
Postby iani1.1 » Sun Feb 20, 2011 9:14
are you thinking about doing something like this?
alex_n/a
christi wrote:Good luck! I'd love to steal your idea (sort of) if you do the project :)
I stole it off a similar picture ian posted lol
iani1.1 wrote:are you thinking about doing something like this?
that's exactly what I want to do. do you know where to get that elbow, is it from the turbo model? or is that the 250$ corksport outragesly priced one?
Sumaire
Postby Sumaire » Sun Feb 20, 2011 9:14
Something that might be worth investigating would be something that Advance Auto Parts carries - Spectre makes a line of modular intake system components that *might* (I honestly haven't done the research as to whether they'll have all the right bits, but it wouldn't surprise me if they did!) just work for what you're after. The parts are fairly inexpensive individually, but I don't know how much you'd be looking at, once everything is added up.
Good luck on the project, boss! :)
2006 Subaru Impreza WRX STi "Sumaire"
World Rally Blue Pearl
415 bhp, 410 ft-lbs
...And yes, it can actually take corners now, too. :)
"Racing makes a heroine addiction look like a vague craving for something salty!"
alex_n/a
Here is what i'm thinking (work with me on the angle lol)
by down pipe I mean it will angle down. and down pipe #2 is where it will drop down in front of the radiator like this
except it will have an air filter not intercooler
and here is another picture
christi
Will that restrict too much airflow though? I would think the photo Ian's picture showed would be better for air-flow-movement than straight down in the last few pictures you posted... I could be wrong, though.
alex_n/a
you might be right christi, I also thought of this, the post is from a guy i know named steve, (the guy friends with the red lt1 fd,calls him zitco citco)
clokker wrote:Today's project -part of my Summer of Fun Around the RX Tour- is my attempt at an intake mod.
I've watched with interest the various threads on this and finally got around to it myself. One thing that's bothered me is the tendency to call such a mod a "Cold Air Intake" (CAI for short) when in fact, the best you can hope for is ambient air temp, unheated by the engine bay.
Hence the thread title.
There were a number of criteria I set for myself...
-the mod had to be reversible (in case it doesn't work as planned-DOH!) with minimal evidence of intrusion
-it had to look as factory as possible, which meant scouring the junkyard for appropriate parts
-I did not want to sacrifice performance for looks
-it had to be an all-weather solution, resistant to rain, snow, etc. (time will tell about this)
Yesterday I spent several hours in the broiling sun rambling through my favorite junkyard, looking for a suitable tube arrangement for the intake.
I'd already decided to retain the stock intake from the throttle body to the AFM so all I needed was tubing from the AFM forward. This was tricky since room was at a premium and I needed at least some flexibility in the tube, so all the hard ABS pieces were basically out.
After pondering all the Hondas, Toyotas, Subarus,etc. I was about to give up and hit Home Depot when I literally stumbled across the perfect piece(s).
It was lying on the ground, obviously discarded from someone's frenzied "rip-the-****er-out" engine pull but as a result, I have no idea what this came out of.
Ultimately I could hardly have asked for a more perfect unit, I'm sorry I can't pass along the info if anyone cares to try this themselves.
Anyway...
This morning I started by stripping the entire front of the bay...
All this so I could cut the hole in the passenger side of the rad support, shown here (already lined with c-channel molding)...
I used a jig saw with a fine toothed metal cutting blade and the whole process took about five minutes. The cut took me right through an unused capture nut and also a little l-bracket that was spot welded to the main support.
The remaining half of the capture nut popped of with pliers as did the rest of the bracket (never was sure what that bracket was for anyway).
The edge was quickly sanded smooth with a drum sander (it was already pretty clean) and the molding applied (I have lots of this cause I use it on fan/rad holes in my computer builds).
The molding not only looks nice but also protects the plastic tube from the sharp metal edge.
Because the filter was going to occupy the space where the radiator overflow tank lived it was necessary to relocate this part.
Looking to the drivers side I saw all the unused holes (for relays,etc., I assume) and it looked like the tank would fit, so I tried it and hark! almost like it was made to go there...
This required just minimal persuasion to line the brackets up with the threaded holes. Saves me from having to fab up a tank, too.
I also relocated the horn(s) to get them out of the direct airflow- dunno if it'll matter but it was easily done, so why not?
It's amazing how many unused threaded fittings there are in this car and how convenient they can be.
So it was finally time for the first test fit...
YAY!
Looks like it's going to work!
But...but...it's not very straight is it?
Well no, it isn't and here's why...
I had to make sure the radiator would still bolt up and that left a very small area to work with.
This arrangement fits about as closely as I could hope for with fabbing up custom rad brackets...which I had considered early on but discarded because of the domino effect (you know, you move one thing and all of a sudden three other things have to be changed- in this case, custom rad hoses and the shroud wouldn't fit and so on down the line...).
It almost looks like it came this way.
Now to install the CF panel I scored months ago from Vipers and finish off the AFM mounting bracket and the air pump filter and we have this...
And finally, a shot from under the car to show the filter in place...
This filter is a K&N left over from my Z project and may in fact be too small but I didn't know exactly how much room I was going to have to work with before I started so I decided to try it out.
I haven't driven the car yet (there is a Phase II to today's project) but while running it to fill the coolant she didn't seem to have any trouble hitting high revs, so maybe I'll get lucky.
If not, I'll just get a larger filter.
This car is my DD and she's got a semi-tired engine (compression in the 80's and low(ish) oil pressure, but runs well with no starting issues or quirks) so there isn't any dyno info to present, nor is it likely there will be any soon.
If anything obvious presents itself I'll report but otherwise no performance claims are being made.
If nothing else, I think it looks bitchen and it only cost $2 for the junkyard tubes (the filter I already had) and is completely reversible.
Not to mention it was a fun way to spend a Sunday.
As you were.
Postby RX-7 Chris » Mon Feb 21, 2011 9:14
why not just do the Bönez Street Comp Intake?
http://www.rx7.com/store/rx7/fcintake.html
Postby iani1.1 » Mon Feb 21, 2011 9:14
yea its the corksport one.
but you can just use the turbo intake elbow. its the same just upside down.
http://cgi.ebay.com/ebaymotors/turbo-2-Mazda-Rx7-FC-Aluminum-Intake-Pipe-88-92-_W0QQcmdZViewItemQQhashZitem1c16b31552QQitemZ120639919442QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories#ht_3470wt_1165
Users browsing this forum: Baidu [Spider] and 75 guests
