100mpg 2 cylinder 4 piston engine
Postby speedjunkie » Fri Feb 04, 2011 9:14
http://rotarycarclub.com/rotary_forum/showthread.php?t=13306
http://www.engineeringtv.com/video/Opposed-Piston-Opposed-Cylinder
This is no wimp engine.
It's a two cylinder with four pistons delivering 300+ Horse Power
It's extremely small and very efficient and is presently in use in test applications
The configuration below is equivalent to a extremely ballsy four cylinder engine
When doubled, it's an extremely ballsy 600+ H.P. engine
It’s called OPOC (Opposed Piston Opposed Cylinder), and it’s a turbocharged two-stroke, two-cylinder, with four pistons,
two in each cylinder, that will run on gasoline, diesel or ethanol. The two pistons, inside a single cylinder, pump toward and
away from each other, thus allowing a cycle to be completed twice as quickly as a conventional engine while balancing it's own
loads.
The heavy lifting for this unconventional concept was performed Prof. Peter Hofbauer. During his 20 years at VW, Hofbauer
headed up, among other things, development of VW’s first diesel engine and the VR6.
The OPOC has been in development for several years, and the company claims it’s 30 percent lighter, one quarter the size and
achieves 50 percent better fuel economy than a conventional turbo diesel engine.
They’re predicting 100 MPG in a conventional car!
Operator
Postby Operator » Fri Feb 04, 2011 9:14
speedjunkie wrote:They’re predicting 100 MPG in a conventional car!
I'm sure the oil industry will be pleased.............
JL 1000/1 - JL 450/4
[/font]
Current:
Postby RX-7 Chris » Fri Feb 04, 2011 9:14
that looks cool
datsun_d
Postby datsun_d » Fri Feb 04, 2011 9:14
awesome! coolest thing I've seen in a while.
Postby erod550 » Fri Feb 04, 2011 9:14
Very interesting. Hugely increased mpg without sacrificing performance. It's a win-win.
Postby AIM WO4 » Fri Feb 04, 2011 9:14
The torque on and 8-cyl twin turbo would be insane!
Postby dommo_g » Fri Feb 04, 2011 9:14
Wonder if we'll see that in any consumer applications anytime soon?
More:
I've been watching this one for a while since it's somewhat rotary-ish.
http://quasiturbine.promci.qc.ca/
Intake (aqua),
Compression (fuchsia),
Combustion (red),
Exhaust (black).
A spark plug is located
at the top (green)
Typical comparison:
Engine displacement versus the Total engine volume
4 strokes engine type.....Unit displacement.....Engine volume
Piston.....................................1...... .............15 to 20
Wankel....................................1....... ............5 to 7
Quasiturbine.............................1........ ...........1.3 to 2
Here's a couple I found interesting that, unlike those posted above, have actually run under their own power.
RotaryICEman's "open source" design:
http://www.youtube.com/watch?v=TSxqdJ-B7_k
RadMax engine:
http://www.regtech.com/Radmax_Technology/
They claim that the 40 lb. prototype made 42 HP at 7000 RPM running on diesel. There used to be a video of them test-firing it on an engine dyno, but the link appears to be broken.
Users browsing this forum: Baidu [Spider] and 62 guests
