Fixer upers - car almost "good" to go
christi
Postby christi » Sat Jan 15, 2011 9:14
I thought I'd post a new thread, since this may be more relevant than a bad idle....
Since I purchased the car there was always that check engine light... I'm not sure when we actually changed the OMP, but it did fix one problem, just not the others. Since the Smog Pump is not working properly, the check engine light still is on, no new codes are producing though whenever I try to get it read.
I have done this so far to the car...
*omp change
*spark plugs
* air filter (dear god, it looked worse than the spark plugs we changed.. Eric lol)
My next list is fix the remainder of what Mazda didn't fix..... the exhaust leak.
I thought for a while my starter was bad, because she would quit starting up for a while, and then start again. Lo and Behold the terminal to the battery was *extremely* loose....after tighten it down, she started right up without slight hesitation, and I don't have to always pump the gas before having her start. When I do, it's because she's trying to flood.... It's strange.
The issue now, we believe is the smog pump.. .because it's not driven by the belt, there force forcing fresh air into the exhaust stream... the higher pressure exhaust gasses were blowing forward thtrough the pump into the intake system (Which is why when I changed my Filter yesterday, it looked BAD; and burnt..... I should have taken a photo lol). This may be causing the code 10 (bad MAF sensor.. By the way, you cannot change that sensor as 1 part. It's the ENTIRE part that has to be change.. a $185 part at that) that's reading when I had gotten it tested after we changed the OMP last month. However, the car is certainly still losing power when I go up on a incline, (I do not believe it's the elevation of CO.... Maybe *part* of it, but not 100%...), since the engine was/is essentially sucking on it's own fumes.
The other potential lead that i've found to the code is the unknown disconnected whire in the wire loom that leads to the intake air flow sensor - all the wires that are hooked up to that AF sensor are connected.. So that one random wire *may* be the answer.
Do you think also because I'm losing power on long uphill slopes.. is because I'm holding a low RPM, and I have almost no torgue ... and I already have to open up the throttle a lot more to get enough power to get up the hill -- and since the engine is/would be sucking in a lot more air, it would have an even lower pressure in the intake side... and even higher pressure in the exhaust system -- even *more* exhaust gasses would be getting pulled into the intake... which is reducing my already limited low-rev-range power considerably?
I can say .. however, after blocking the hose that was connected to the intake, the car is "breathing" better than ever, although now it sounds like i have a exhaust leak in the engine, lol. I'm going to try to block/delete out the smog pump (hole)... tomorrow, and see if the check engine light goes away.
Any thoughts? Ideas? ...
I'll be going to the Mazda Tech Day Feb 18th that someone is holding here for one of the events north of Denver. I, in hopes will be rid of the check engine light... and maybe just be able to get a decarb on the car..... and possibly a compression test.... Then I HOPE she'll be ready by Deals Gap!
Postby geo2maz » Sun Jan 16, 2011 9:14
dayum girl, you know a lot about cars, more than i, sorry can't help, i'm durnk, so catch me @ the drunk post, peazout
Postby iani1.1 » Sun Jan 16, 2011 9:14
yea, thatll do it. since you have an stock na rotary (which has almost no torque), anything above 2500-3000rpm going up hill is recommended
the smog pump shouldnt affect the engine light. though it is an s5. you can just replace the afm and put that mystery wire where its suppose to be.
Postby RX-7 Chris » Mon Jan 17, 2011 9:14
What color is the plug for the disconected wire by the air flow meter?
christi
Postby christi » Mon Jan 17, 2011 9:14
Geo - I try. I'm learning still. I like to tinker, but by all means I'm not good :P ... I'm getting there though. heh.
It was eventually my starter. Part of the solenoid (sp?) was...broken. What seems to be the car wasn't turning fast enough for when the starter was engaging... I guess?
Bought the starter - works good as new.
Check engine light still on.
Now... .time to tel if it's the MAF thermo sensor, which if it is.. its a 185.00$ replacement. If it's not, it's the one on the engine near the manifold I think.. but I have no idea where it's at.... on a second gen.
I'll tell you thouggh, my ghetto rigged way of blocking off the airflow from the air intake filter and where the smog up used to be is great. Ha ha.
Also, whoever the previous owner went to to redo the transmission surely didn't take part into caring on how to re-wire it... Seriously.. ha ha. I'm surprised nothing bad is actually gone wrong in that area.
I also need to go to the stealership and complain.. I paid them 112.00$ to fix my exhaust leak, and they fixed what appears to be from the engine block to the front half of the cat, but not from the cat to the back end... The bolts are all eff'd up. There's a missing bolt, and what appears to be a bolt all torn apart, and just another one slapped on it. I couldn't get a photo, as it was too dark to show you.. but.. yah.
(Sorry for quality, taken under the car, hard light except for a flash light, and by my iPhone).
http://www.flickr.com/photos/frogmeow/5366187608/ (video)
heh. and my jerry-rigged version of blocking off stuff..
christi
Chris - I don't know the color, I'd have to remove the MAF again to look. I probably will this weekend, and get back with you. Sorry..
christi
Postby christi » Wed Jan 19, 2011 9:14
The unknown wire is stripped. I would have to cut back of the plastic to find out.
Also....the code 10 was revealed by the OBD1 reading for the termosensor. Per the manual it's either on the MAF sensor which would need to be fully replaced and a 185$ part or the one by the intake manifold. So...where is that second one anyone know? I'd like to to find out first which one it is before spending way more money than I need too. Thanks guys/gals :]
Sent from my iPhone.
Postby RX-7 Chris » Wed Jan 19, 2011 9:14
I would start by pulling the MAF and cleaning it real good with MAF cleaner.
christi
Chris - That's the problem -- You can't. It's one big piece. The sensor is the entire unit.
Postby RX-7 Chris » Thu Jan 20, 2011 9:14
It's basically the same as my car. You just pull the whole unit and clean it out that way. It is fairly easy to pull.
christi
Postby christi » Mon Jan 31, 2011 9:14
Yeah. I'm pulling it out this weekend and doing a clean. Fingers cross it fixes my check engine light. Also - heh. I found out this past Friday that my car needs a new brake master cylinder. She kinda didn't stop this weekend...and the rears locked up while the peddle went to the floor. Yeah - fun stuff.
christi
Postby christi » Sat Feb 05, 2011 9:14
Freaking snow!! I've yet to get my breaks fixed -- once that's done and the MAF sensor, I'll begin my actual *mod* process :D
christi
Postby christi » Wed Feb 16, 2011 9:14
Brakes will be fixed as of tomorrow! I tried to drive the car yesterday; and she would coast.... and not stop HA. Only my luck.
Once we fix this + the tech day, I think I'm going to make another thread for my modifications. I have a few things in mind; but would love your input as well :)
christi
Postby christi » Thu Feb 17, 2011 9:14
I just wanna say F changing the brake master cylinder. That thing is a total biatch.
Postby Learjet45 » Thu Feb 17, 2011 9:14
So does that mean you got the brakes fixed? lol.
