So besides the random dying it ran good, right?
AFRs were a little rich in boost but I want it like that until we get you on the dyno. Timing and fuel should be safe to 27-30psi.
We'll get the random dying straightened out soon! Problem is I'm not convinced if it even a tuning issue or a mechanical at this point.
My own thread...now with more issues!
So what happened to your motor?
it is a Rotary FD, Don't they only run a few months at a time?
I think a side seal (or two, one on each rotor possibly) might have melted or the spring is bad or something. Compression still sounds decent even on the low spot but you can definitely tell a difference. I'm still wondering if something else is wrong too. I was thinking I might need to check my injectors to make sure they're firing. I'm wondering if maybe the primary for the front rotor isn't injecting, because the rear rotor spark plugs always have fuel and oil on them after trying to start, and the front plugs hardly have any. At least they didn't the other day. Not sure.
Anyway, yeah as of right now I'm planning on pulling the engine and pulling it apart. This will give me a chance to paint/coat the engine and paint the engine bay. I'm just wondering how I should coat the engine itself, whether I should paint it or powdercoat it or what. Someone on 7club has their irons black and the housings and LIM are gunmetal, I think I might do that. First I'll clean them up as much as possible, then sandblast them, then clean them up again and powdercoat or paint. Actually I have a small list of things to do while the engine is out...
-try to clean up all the excess crap in the engine bay (lines and wires not needed)
-possibly go ahead and install the Mazda 929 master cylinder for when I go big brake -tap and install bolts into the excess injector ports on the LIM so the freeze plug doesn't pop out again under boost
-install the Bosch coils
-install an oil pan brace
-repair the power steering reservoir since it appears to be leaking
-possibly relocate fuse and relay boxes
-make more permanent wiring harnesses for the fans
-install a proper power steering fluid cooler
-ceramic coat LIM, UIM, turbo housing, possibly IC piping
There is probably more I'll find to do once I'm in there, but I might as well while I'm there, right Dave? lol
First though, I'm going to clean the garage tonight and make sure the work bench and surrounding area are clear for pulling the engine and tearing it down, and drain all the fluids first. I might start pulling it tomorrow night, or maybe tonight if I get that far. Then once it's apart I'm going to take the parts up to Matt so he can spec them for me, then I'll take care of the sandblasting and powdercoating and put it all back together and after taking care of everything else in the engine bay I'll drop it back in.
I might get some Rotary Aviation apex seals too. I just have to see what all I need once I get it open and inspect. I'm kinda excited actually LOL.
To answer your question Frank, I'm not SURE it needs rebuilding, but I can't figure out what it might be other than that and because the compression doesn't sound exactly the same on all faces I'm assuming it's a side seal and needs a rebuild.
It's just VERY odd because it still sounds strong. That is why I'm thinking a fractured apex seal or something along those lines. Like I said...very odd. It let go without any drama whatsoever.
I want to be there for the rebuild, so let me know when you plan on doing this Eric! I have weekends off so that is best for me to be there, but if that doesn't work out for you just let me know and I can probably get time off work.
iani1.1 wrote:its more reliable than a full bridge thats for sure
Well I would assume so LOL.
chickenwafer wrote:It's just VERY odd because it still sounds strong. That is why I'm thinking a fractured apex seal or something along those lines. Like I said...very odd. It let go without any drama whatsoever.
Yeah, it was very anti-climactic, like the other time it went out haha.
I'm going to take it to Matt to have him spec the parts and I'm going to paint it or powder coat it or whatever after that, then I'll probably build it along with him up there. We were planning on spec'ing and building afterwards but I want to paint it first. So I'll be a lot closer to your side when that happens. Robert wants to be there for it too, I think we might have a crowd haha.
