It taps power parasitically from the diagnostic port using an integral non-removable cable and features a LED-backlit full raster LCD display with ambient light auto-brightness. It can display eight rows of text, and displays simple graphics, multiple typefaces on the gauges. It offers several gauge pages, six gauges per page: top two large, bottom four small. The physical package itself is surprisingly thin and lightweight. There are three buttons (up, down, menu/enter) which by default beep when pressed. They're located on the BACK of the unit, but they're easily used both handheld and while the unit is mounted in its suction-cup holder. The holder is attached to a ~6" flexible stalk on a window suction cup.
My version is the "Dec 2 2010" 1.0 firmware. Firmware updates are said to be free but require the unit to be shipped at expense to the company for updating. In addition to realtime gauges/data, it supports pending trouble codes, trouble codes, and customizable high/low/high+low alarms for each gauge parameter given.
Their forums mention a possible update with extended ecu code support, but they admit they left it out because they thought it'd be too hard to support. Their forum users suggested they either leave it to the user community to support, or just not support that feature, but add it either way.
Here are the gauges it auto-detected and made available in my 2010.5 MZ3 s Sport 2.5l 6-spd:
1. % Engine Load
2. Coolant Temp 'F
3. Shrt fuel trim bank1
4. long fuel trim bank1
5. Intake Pressure abs
6. RPM
7. MPH
8. Timing Advance
9. Intake Air Temp 'F
10. Mass Airflow 1 g/s
11. Throttle Position %
12. Bank1 OS 2 Voltage
13. Run Time ECM
14. Distance with CEL on
15. EGR % Flow
16. Evaporative % Purge
17. Fuel Level %
18. Warm ups TC cleard
19. Dist since TC cleard
20. Evap Vapor PSI
21. Barometric inHG
22. Cat Bank1 Sensor1 'F
23. Battery Voltage
24. Rel Throttle Pos % abs
25. Accel Pedal Pos1 %
26. Accel Pedal Pos2 %
27. Cmd Throttle Pos %
28. Mass Air Flow 2 g/s
29. Instantaneous MPG
There were another 21 gauges derived indirectly, mostly MPG-calculation related and misc like that. Updates appear to occur on a 0.5hz interval.
I think the best thing about this is that the UltraGauge can be had, shipped, for about $75. (Does not include a $9 mail-in rebate available, but you must jump through hoops to get it anyway.) Half the cost of the ScanGauge II, but also offers: twice the screen size and a nice backlit one too, more complex displays, audible alarms, pending trouble codes. The only bit missing are the custom ECU codes, which may show up in a later revision.
A mini-review in video format that I made this morning and posted to youtube:
[ame="http://www.youtube.com/watch?v=rWWEiR3Ag0Q"]http://www.youtube.com/watch?v=rWWEiR3Ag0Q[/ame]
