suspension questions
reconbygod12
Postby reconbygod12 » Mon Dec 20, 2010 9:14
i already have front and rear sway bars, but with those can i still mount anything else with it also i am selling my cobb lowering springs, due to the face am putting coilovers on my car
2008 wrx sedan-new love
09 cwp mazdaspeed 3 GT-gone
04 mazda 6s-gone
Postby RX-7 Chris » Mon Dec 20, 2010 9:14
I'm a little lost on what your question is?
reconbygod12
can i still put on
1.tower brace and lower arm brace
2.member brace set
3.mid chassis brace
with the coilovers and front and rear sway bars or would the set up i hav ebe fine for autocross way it is
04 mazda 6s-gone
Postby tbot » Mon Dec 20, 2010 9:14
strut tower bar and coil overs...call it good since u have the sways already.
reconbygod12
alright apprecicate it because i know nothing about suspension at all
04 mazda 6s-gone
Postby iani1.1 » Mon Dec 20, 2010 9:14
a chassis brace wouldnt hurt for scca. does depend on what tires and your setup is. a tower bar up front and the chassis brace for the rear you should be good. i dont think a bar up front is enough to control body flex. unless they sell tower bars for the rear
With as much as these cars flex...a front is worth it. I've seen it first hand both with my 3 and with the 6.
Justin
Postby Justin » Mon Dec 20, 2010 9:14
I'm not convinced that they're worth it. The car is relatively well braced from the factory and the braces are pretty expensive. The only ones I'm aware of are the autoexe ones and the front strut bar is something like $500.
Postby chickenwafer » Mon Dec 20, 2010 9:14
Most modern 2000+ vehicles are pretty stiff from the factory. Torsional rigidity has increased exponentially in vehicles in the past 8 years as well.
For example, the RX-8 is roughly 220% stiffer than the FD RX-7, which was no weak car to begin with. This is obviously from new, more advanced designed chassis', and also new safety standards.
Bracing on older vehicles, like 2000 or earlier, can be a good idea, but on most newer vehicles, strut tower braces and especially so-called chassis bracing is 99% a waste of money IMO. Only exceptions are when the vehicle is modded well beyond the factory design, i.e. a Mustang that runs 7 second 1/4 miles.
Postby tbot » Tue Dec 21, 2010 9:14
Like I've said, I've seen the flex these cars have first hand. I had a hood pin switch on my 3 for an alarm and after about a month or so of me driving like I normally do, with mountain runs and all, the pin was bent to the side to the point it had cracked, not quite broken, but didn't work anymore. It was mounted about half way down the fender on the drivers side. On top of that, I did notice a difference after installing the tower bar on my 6. Regardless of the rigidity of newer cars, there is still a benefit and I think its worth it. If you troll some of the "other" forums, I'm sure you can find a used one for a decent price.
Users browsing this forum: Google [Bot] and 231 guests
