I got ms6 engine for parts if anyone is interested here those are. One of the cylinders had no compression and the piston cracked and the cylinder block got scratched a little bit - its still good if U want to use it to build an engine. I will post some more pictures later. Rest of the parts are in a realy good condition - will show on pictures. please do not remove the post.
OIL PUMP $140
OIL PAN $180
BLOCK CYLINDER $850
RODS $150
CAMS $180
CYLINDER HEAD $700
CRANKSHAFT $450
WATER PUMP $85
PISTONS $50 ONLY 3/ONE DAMAGE/
TIMING COVER $150
CHAIN $60
Fs:engine parts speed 6
