My own thread...now with more issues!
Postby speedjunkie » Sun Dec 12, 2010 9:14
The skreeching sound wasn't there today, so the only sound you heard was what I always heard before haha. Now, the chattering noise sounds like something more than an exhaust leak to me, but I'm not sure.
As for the injectors, they're not injecting fuel with the key in the on position, so it's not out of the question just yet. The way I see it is they could be making that noise when they're injecting fuel.
Postby chickenwafer » Sun Dec 12, 2010 9:14
They're not injecting fuel, but they are under pressure (fuel pump primes) and the coil is energized just waiting for the ECU to pull it to ground.
If it was a wiring problem then you would hear it. I'm not ruling it out, just thinking it's kind of unlikely.
Well maybe I cracked the phenolic gasket and it broke already, I don't know haha.
EDIT: I felt for air leaks around the LIM while it was running and I definitely have a leak. So I guess I'll be pulling that back off to see what's up.
Postby chickenwafer » Mon Dec 13, 2010 9:14
speedjunkie wrote:Well maybe I cracked the phenolic gasket and it broke already, I don't know haha.
Ahah! Success! I knew I heard a leak.
Postby speedjunkie » Mon Dec 13, 2010 9:14
Since I hijacked the HELL outta Dave's "my new car" thread, Chris had a great idea about starting my own thread haha. I already felt bad about it anyway so here is the new thread. Chris, can you move mine and Dave's posts about my car over here? Thanks!
Yeah now I just gotta take off my compressor housing, UIM, disconnect fuel lines and everything and take the manifold back off...just to put it back on haha. And I hope that's it haha.
Hey Chris, can you move this stuff into MY thread? LOL
http://www.coloradomazdaclub.com/forums/showthread.php?p=115072#post115072
Stealing from my thread, huh!
But really, I thought you already had a thread? http://www.coloradomazdaclub.com/forums/showthread.php?t=3847
Postby iani1.1 » Mon Dec 13, 2010 9:14
haha wow
Yeah I remember that thread, I was mainly just starting this one for these current issues but couldn't think of what to call it exactly haha.
OK, I got the LIM and all that off. The gasket is not broken, cracked, or damaged in any way! I have NO idea how this thing isn't sealing. I'm thinking about putting high temp RTV on there and reassembling, but I really don't want to have to take this all back apart again. Plus I'm not sure if it would stay sealed anyway even with the RTV.
The LIM has some dimples in it, but none along any edges to where it wouldn't seal. Man I'm confused.
I'm going to check around and see if anyone else is using the Gizzmo LIM gasket.
Postby chickenwafer » Tue Dec 14, 2010 9:14
What kind of gasket did you use? If it's a stiffer material type like graphite or something could can fracture it by torquing the LIM down too hard.
Also double check both mating surfaces are true, you might need to be the GZ manifold machined down 0.030" to make it truly flat. I've heard about some issues with the GZ manifold and the casting quality to be rather poor.
Postby RX-7 Chris » Tue Dec 14, 2010 9:14
Moved Posts over
Postby speedjunkie » Tue Dec 14, 2010 9:14
Thanks Chris! Lemme know about those fenders haha.
chickenwafer wrote:What kind of gasket did you use? If it's a stiffer material type like graphite or something could can fracture it by torquing the LIM down too hard.
It's the Gizzmo phenolic gasket. I'm not sure what it's made of but there isn't much flex to it. I torqued the hell out of it though to try to get rid of the leak so it can take some abuse without cracking, but I really don't want to test it too much haha.
I never had a problem with the stock gasket sealing so I don't have any reason to believe the mating surfaces are off.
Zico said something about tightening the bolts down in the torquing pattern (which I hadn't done the first time), which would be starting with the middle bolt and then alternating sides. I might try a slight film of RTV and the torquing pattern and see what happens. I'm not going to put the turbo housing back on to test it though, that's the hardest part to get off lol.
Yeah, try the torquing pattern, it makes a big deal, especially with something with a mating surface as wide and narrow as the LIM
speedjunkie wrote:Thanks Chris! Lemme know about those fenders haha.
I never heard from the guy who said he would call me. So they are yours. I'm not going to have a chance to pull them till after Christmas though. Did you ever find out about the cherry picker?
Users browsing this forum: Bing [Bot] and 102 guests
