1994 FD RX7 - Hello, Computer?
Postby chickenwafer » Sat Oct 16, 2010 9:14
Matt, I saw this on 7club and thought of you,
http://www.rx7club.com/showthread.php?t=901169
Guy built a simple board with a serial cable output that reads the stock ECU. He also wrote his only software in C+ that allows you to log it. Looks pretty simple! You can tap into the diagnostic connector as well so you don't have to touch the ECU.
Also found out some more info about the stock ECU. It's 8bit that provides a maximum of 6 data logs per second, uses a Motorola chip and it IS NOT flashable/writable. You would have to install a daughterboard in with a writable chip in order to make direct changes to any tables within in the ECU
Postby iani1.1 » Sat Oct 16, 2010 9:14
wow that is pretty cool and all on the stock ecu.
It's just datalogging thus far, no changes to the parameters within the ECU at all. At least, not yet.
Postby RX-7 Chris » Sun Oct 17, 2010 9:14
that is really cool
alpha
Postby alpha » Tue Nov 30, 2010 9:14
Hey guys,
I build the opto-interface on that website and downloaded the guy's software on my test machine.
So far, I haven't been able to communicate, although the hardware I built appears to be working. I signed up for RX7club.com just so I can ask a question about port settings. :confused: Hopefully that's my only problem.
The software is buggy but 'cute'. He has these simple gauges for displaying data, unfortunately mine are always at "0". If you want to run the software you will need the .NET framework from Microsoft. I'd do it on a spare machine since I haven't checked his code for viruses or memory leaks or anything.
If I get it working, maybe we can make a small batch of the hardware for anyone who's interested. Hopefully I will get it figured out this month.
Matt
Postby chickenwafer » Tue Nov 30, 2010 9:14
You work fast Matt!
Good stuff
alpha
Mission Accomplished
Postby alpha » Wed Dec 22, 2010 9:14
Using the information posted by chickenwafer, I built this little gizmo...
that allows me to talk to the factory ECU using a program written by a guy in New Zealand! Because of which, today 1:47pm at my house, we have made first contact!
Now, you will not be able to watch anything real-time... IT IS SLOW... I mean dog slow... snail slow... 1958 VW Bus with an automatic transmission westbound I-70 slow!!! I'm lucky to get 2 readings a second, but at least we have communication.
Finally, Computer says 'hello' back...
- alpha -
Users browsing this forum: Bing [Bot] and 102 guests
