Turbo Manifold
bobopud
Postby bobopud » Wed Nov 28, 2007 9:14
Protege Garage has recently anounced an upgrade to the turbo manifold for the speed3, 6, and CX-7. I was wondering if anyone has any thoughts on this. The group buy on 247mazdas.com is for $399, which sounds like a steal for a well made turbo manifold. Opinions?
Postby SpeedRacer » Wed Nov 28, 2007 9:14
Is it steel or whats it made out of?
Rich
Postby Rich » Thu Nov 29, 2007 9:14
Yeah, is it going to glow at night or what? I'd like to see something ceramic coated at least...
bobopud
Postby bobopud » Thu Nov 29, 2007 9:14
It is stainless I believe. I'm sure you can send it off for ceramic coating once you get it, probably another $200 or $300 on top of the cost of the mani. I'm still on the fence for this, but the price is what caught my attention. Hard to beat a $90 discount for a group buy. I will probably wait though, I already had to cancel my order for the standback thanks to my fight with the damn concrete pillar.
Postby MazdaTom » Thu Nov 29, 2007 9:14
I got my 4-1 header for my car ceramic coated here in town for $150 at Premeire Coatings. Jet Hot quoted me $165 + shipping and handling. I got my header coated in a lower temp coating because my NA motor doesn't produce the high exhaust temps you turbo guys see- but a higher temp coating is an option at this place. And from talking with the owner, for best performance of the coating, get it coated before you ever use it- cleaning ALL the carbon deposits off the inside can be challenging depending on the design/shape of the manifold. He said I "might" see some discoloration because he couldn't gurantee that he cleaned the inside of my header completely.
I'd say go for it. I've saved a bunch of my money (without switching to Geico) from buying parts used and through Group Buys.
arctic_blue83
Postby arctic_blue83 » Thu Nov 29, 2007 9:14
Not a bad price for a tubular manifold. Although be wary, on turbo cars, the extra heat retention combined with weight they support often leads to cracking. It would be best to check and make sure they are using some sort of extra bracing to support the weight of the turbo. I've seen people use tubular manifolds for 2-3 years and never have a problem, but then again, I've also seen people crack them in under a month... kind of a coin toss. They should be good for a decent power increase over the cast iron stocker though. Good luck!
bobopud
They do mention extra bracing and support built in their design. What exactly happens if a manifold cracks? Is it disasterous to the engine, or could I just swap in the old one and be on my way?
arctic_blue83
<div class='quotetop'>QUOTE (bobopud @ Nov 29 2007, 11:49 AM) [url=index.php?act=findpost&pid=12495]<{POST_SNAPBACK}>[/url]</div>
They do mention extra bracing and support built in their design. What exactly happens if a manifold cracks? Is it disasterous to the engine, or could I just swap in the old one and be on my way?[/b]
Swap the old one in and be on your way. Your underhood temps will be a bit higher, but it shouldn't really hurt anything. You might be down significantly on boost in the meantime, so the car won't run too hard.
Rich
Sounds like a ceramic coating would go well with the extra bracing if you can afford it.
Users browsing this forum: Bing [Bot] and 108 guests
