I'm new to the area and I wondering how different boost level are here at altitude. At sea level i'd see 17 psi easy on a stock tune but up here I see it in the mid 15s.
Also, my AFRs at WOT are in the low 12s when I used to see them mid to low11s. Am I loosing my mind or is this normal?
High Altitude Boost
High Altitude Boost
You're seeing AFRs at WOT in the low 12s on a stock tune?
I don't know if you should be worried but I don't think you have a stock tune. Stock runs pig rich and puts you in the low 10s to the 9s by like 5k rpms. Did you buy the car used? Maybe someone else had flashed the ECU before you got it and never put it back to stock before trading it in.
Don't have an AP so it'd be kinda hard to pull that one off. I'm wondering if it is either my mods on the stock tune or the gauge I am using. Right now I have an Aeroforce Interceptor but back when I was at sea level I had an AP. Sounds like I will have to confirm with an AP when I gather some funds to get one again. Everything seems fine though because my exhaust has a bunch of soot on it as always.
