My New Toy
I made a little progress last night. I faught with the clutch for over an hour and got nowhere. I also removed everything so I could replace the oil line. It requres a 26mm (I think) to remove the oil line. I only have through 24mm.
I ended up borrowing a monkey wrench from Ian and I did get the new oil line on. I'm going to change the oil after work today. I looked up the price to buy a 26mm wrench at sears and it was $18.
I'm going to need to swap out the clutch line and slave from the black car also today.
RX-7 Chris wrote:I ended up borrowing a monkey wrench from Ian and I did get the new oil line on. I'm going to change the oil after work today. I looked up the price to buy a 26mm wrench at sears and it was $18.
I went to Sears to pick up my hex sockets. $6 for one, $10 for the set. Makes perfect sense.
The car is on the road and driving good. I fixed the clutch, changed all the oil (motor, tranny, and rear), had the wheels swapped, and had an alignment done.
I was able to drive the car to the meet as well.
Next on the list is fix the exhause leak (needs a new gasket between the mani and the downpipe). Than it is replace the O2 sensor, chean injectors, fix 6 port actuators, and replace all old vacuum lines.
I took the car on a drive to the salvage yard and on the way back the car stalled. The fuel filter clogged. i was able to jack the car up, pull the filter, and bang it out. The car ran after that. I think this is going to be some thing I will have to deal with untill all the rust comes out of the tank.
iani1.1 wrote:wow it clogged that quick? that's pretty bad. oh yea i wasnt able to find a useable gasket.
Not a problem, I looked on mazdatrix and the FC gasket is a little different.
I had some fun with the simple green today. I started to clean under the hood. I finished the underside of the hood and started on the inner fenders.
Here is a before and after:
It does. I didn't even have to scrub, just spray and wipe off.
I'm trying to fugure out the fuel tank problem. I found this great writeup: http://www.rx7club.com/showthread.php?t=921808
- Renesis Rx
Users browsing this forum: Baidu [Spider] and 99 guests
