FD GT40 Build
Yeah, you will need a metric shit ton of more fuel man. I'm not trying to be a downer...I just don't want you to blow you motor.
I'd upgrade to at least swapping your stock secondaries to the primary rail (you have to mod the rail to do this), that would give you the classic 880/1680cc setup most people run, but that's on pump gas. E85 requires at least 30% more fuel.
I would strongly recommend Injector Dynamics fuel injectors. These things are amazing- further more they are high impedance injectors so you don't need resistors or anythings. Truly plug-in-play.
Also, due to their driver system, you can run 1,000cc primaries and not run into low rpm/idle fueling issues. They can run extremely low and high duty cycles without problems.
The bad news is, they are pricey, but they are truly a 21st Century fuel injector.
Also, with E85, you need more fuel flow, so you need a lot of fuel pump. For 5-600rwhp you would need twin Bosch 044 pumps. A Walbro will only be able to handle around 350-rwhp at best. Denso Supra pump could get you around 400rwhp but that would be real close and on the edge.
You could run a Denso in-tank with an in-line external Bosch 044 and that should get you closer to 500rwhp with E85 in a rotary. Remember, rotaries require a lot more fuel than typical piston motors, as well.
turboholic
Here is a great site for you: http://foxed.ca/foxed/index.php?page=rx7manual
turboholic
thanks.
Im trying to get the aem to sync with my crank. The FD only has 1 timing mark at 20* ATDC which is useless because I cant keep the car running at that degree.
I just found a way to mark 10* BTDC on the pulley so I should be able to sync it now.
93 RX7 LSX 6L
05 RX8 LS1 build in progress
93 RX7 1.3L
S14 11:1 T3/T4
93 RX7 1.3L
S14 11:1 T3/T4
turboholic
Finally getting the AEM dialed in. Wastegate is opening around 12-13 psi and it's open atmosphere dump. It's a little loud, im contemplating having it routed back into the exhuast.
There is no feeling like T4 turbo boost on an rx7.
Gotta work on all the drivability tuning now.
93 RX7 LSX 6L
93 RX7 1.3L
S14 11:1 T3/T4
93 RX7 1.3L
S14 11:1 T3/T4
Users browsing this forum: Baidu [Spider] and 92 guests
