Calling MS3 owners, whats your PSI?
mOOsE
Postby mOOsE » Mon Apr 20, 2009 9:14
Did a couple searches but it seems that most people who log their results are usually modded....so I was just curious if anyone had any stock-boost readings at our elevation? Especially readings for both 2nd and 3rd since the limited 1st and 2nd gear stuff. I recently purchased the Rev app for my iPhone along with their Wifi adapter and have been logging some runs so the curiosity has definitely set in.
Postby movovr » Mon Apr 20, 2009 9:14
15psi (stock), 18 psi secondary (which is becoming my daily driving choice lol)
mOOsE
wow, I haven't gotten close to that...may have to do a few more runs and see what the max recorded was...
Postby movovr » Tue Apr 21, 2009 9:14
What kind of mods do you have on the car?
mOOsE
Postby mOOsE » Tue Apr 21, 2009 9:14
just the MS CAI. Took a look at my logs from a few runs.... 2nd gear is hitting max of 10-11psi. 3rd and up is showing a max of 11-12psi. I am def leaking somewhere if you are hitting 15.... sh1t
Rich
Postby Rich » Tue Apr 21, 2009 9:14
^Agreed. Sounds like a boost leak to me.
mOOsE
crap, and I hate to order a new BOV just to see if thats it (it probably is, the plastic ones are junk)....might test my friends MS6 and see what he's boosting as well...if he's ok I can steal his for testing...
Check the hot side boost tube to the stock TMIC (specifically where it connects to the turbo) When I had an upgraded TMIC and did the tube upgrade at the same time, the damn stocker practically fell right off the turbo! Worm clamps FTL:3039183a: I've heard of many speed 3 owners discovering the same issue...
Gmoney
Postby Gmoney » Tue Apr 21, 2009 9:14
I just noticed the same thing when I got the Aeroforce gauge........I was only hitting 12-13psi in 3-4th at WOT......(MS6).......found a leak in the point where the TMIC connects to the cold pipe.......made a rubber gasket, used the metal stock one as a template......bingo 14-16psi now.........only found it by using soapy water.......I am running a ETS 3.5 though....good luck......I am going to be replacing all the clamps with T-bolts as soon as I can get an inventory
*CP-e CAI
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*RPM LED Side/Rear Markers
*SU Rear Engine mount
*Cp-e Rear Diff Mount
*TurboSmart MBC
mOOsE
Postby mOOsE » Wed Apr 22, 2009 9:14
Gmoney wrote:I just noticed the same thing when I got the Aeroforce gauge........I was only hitting 12-13psi in 3-4th at WOT......(MS6).......found a leak in the point where the TMIC connects to the cold pipe.......made a rubber gasket, used the metal stock one as a template......bingo 14-16psi now.........only found it by using soapy water.......I am running a ETS 3.5 though....good luck......I am going to be replacing all the clamps with T-bolts as soon as I can get an inventory
Well, checked the hoses...none were loose but I gave them all a few extra turns just to be safe...my guess is the plastic bpv still... Wasn't planning on replacing it so soon. Do dealers even warranty this kind of thing (noobish question)? Otherwise I might rock a black forge BPV since it looks just like stock.
Postby Colombia28 » Wed Apr 22, 2009 9:14
mOOsE wrote:Well, checked the hoses...none were loose but I gave them all a few extra turns just to be safe...my guess is the plastic bpv still... Wasn't planning on replacing it so soon. Do dealers even warranty this kind of thing (noobish question)? Otherwise I might rock a black forge BPV since it looks just like stock.
When i did some logs back in the day with a dashhawk, i would hit the 15.6 in 3rd-6th, but it would bleed off fast and stay at 10psi to redline. Still running the stock bpv and haven't done another log since. Some say an aftermarket bpv will take care of the bleeding problem, but iv seen evidence showing its the same, and boost still bleeds off.
Its probably not a bad idea to replace the plastic pos that mazda thought was adaqute, but i would not get the forge. It sounds like crap. Yes, it looks identical to stock only metal, but man does it sound bad. It litteraly sounds exactly like its name. Every shift, every change in throttle sounds like an iron worker guy hitting the two metal things together. Many here have gotten the HKS SSQV and love it. Its what i will get when i eventualy get off my bum and pick one up.
Postby kingtut » Wed Apr 22, 2009 9:14
I second what Columbia said about Forge. When researching them, people said it sounded like a sword fight- ching-ching!!
^Off topic, but sweet avi tut!
Colombia28 wrote:^Off topic, but sweet avi tut!
Thanks dude- I was going to the range pretty regularly, but have since slowed...too 'spensive!!
Oh yeah...and I think I'm ordering an HKS tomorrow:)
kingtut wrote:Thanks dude- I was going to the range pretty regularly, but have since slowed...too 'spensive!!
I bet. And sweet on the HKS! Post up some pics if you get it.
Users browsing this forum: No registered users and 90 guests
