Specs:
'04 Manual RX8, 36,500 miles.
Last "Full Circle Inspection" at 33,000; all 'green.'
Stock engine, no modifications
Purchased at 34,500 - driven it with no issue.
On Tuesday morning I walked out to the car, used the keyfob to unlock the doors, got in, depressed the clutch fully and turned the key. Nothing. No cranking, no noise at all, in fact.
I noticed that the radio did not come on, and after getting out to look and back in, I noticed the keyfob didn't work anymore, either.
Thinking that the battery was dead (I believe it had the original factory battery), I tried to jumpstart it with a jumpstart kit AND another car to no avail.
I went out this afternoon to get the battery tested and it was putting out 12.5 volts. Not fully charged, but enough to get a car cranking, at least. I noticed when I pulled the battery out that it hadn't been seated well and the caps were a little bent, but nothing major. Praying to Jebus that it was just a dead battery, I bought one on the spot ($90..) and threw it in.
Still nothing. It's acting exactly like what happens when you try to turn it on without your foot on the clutch... dead silence except your key turning past the "ON" position.
What could this be? I was thinking it was a clutch position sensor or something, but that doesn't explain why the radio and the keyfob don't work.
I pulled the 60A fuse right on the battery housing and it looked fine, as did all the little fuses I could pull out in the fuse box.
Tuesday was particularly snowy and cold and the car ran fine driving 100+ mi on the previous Saturday in the snow..
HELP? I've already spent $90, and I don't want to have to pay to tow it to the dealership for nothing.
Cross-posted on rx8club..
8 won't start, won't even crank..
- GTConversion
- RedRoadster
Aftermarket alarm system? A dead one may have a fail-secure ignition kill..
95 Classic Red Miata - 'Kona'
Flyin' Miata stuff:
Flyin' Miata stuff:
- GTConversion
turbo99jetta
- RedRoadster
second on the fuse check. test it with a multimeter for continuity.
Flyin' Miata stuff:
Flyin' Miata stuff:
- goldrocket
Does the radio turn on? Does the rest of the electrical system work? Sometimes the starter or the soelonoid goes bad, and will cause a drian on the charging system. If it's locked up it will cause the symptoms you are describing. Can you roll start the car?
Al says
- GTConversion
- GTConversion
- RedRoadster
fuses that look physically fine can still be borked and not conduct.. (BTDT) get yourself a cheap $10 job from Radio Shack or Wally world or some such..
Flyin' Miata stuff:
Flyin' Miata stuff:
You can pull those big fuses using a pair of needle nose pliers, or some other form of pliers. By the way, they're called "relays", and aren't actually fuses in the typical sense...more like electrically operated switches. Unfortunately you need a special tool to test them, so pulling them won't do much good, unless you are troubleshooting a voltage drain (good idea).
- GTConversion
- GTConversion
Well, if it ends up being a warrantable issue, then that fee should be waived. Don't get suckered, Mazda of Lakewood tried to sucker me into buying a clutch for my 2nd gear syncro issue. If they're towing you for free, they should be diagnosing for free, since you're still under bumper-bumper.
I'll say this, any of the dealerships in Denver I've taken my car for diagnostics/work, none of them have charged me a fee just to look at it.
