Unichip PnP Engine Management for Speed 6
firestoned
Postby firestoned » Fri Mar 21, 2008 9:14
Has anybody heard of when this is coming out? Streetunit has preorders on their website now. Im wondering how it will stack up to CP-E....the unit seems to come 'pre-mapped' to your specific aftermarket parts from Streetunit themselves. Check it out
PRE-ORDER NOW, SUBMIT PAYMENT LATER!
All you have to do is choose "Pre-Order, Pay Later" as your payment method at checkout. This will lock your order in at the heavily discounted introductory price and hold your spot in production shipment. When the units are ready to ship, we will contact you to choose your performance map, shipping options, and payment method.
2006-2007 MAZDASPEED 6 Plug & Play Engine Management System by Unichip
An Exclusive Product of Street Unit Performance, Inc.
Part Number: 1320031
Unichip Plug & Play Kit Includes: Unichip piggyback processor, plug & play harnesses for the MS6 OEM connectors, all wiring, mounting hardware, and color instructions.
plug and play -jargon:
1. Hardware or software that, after being installed ("plugged in"), can immediately be used ("played with"), as opposed to hardware or software which requires complex installation and/or configuration.
Easy Installation is a very convenient feature that the Unichip's simple Plug 'n' Play harness allows. The Unichip module comes with a MAZDASPEED 6 specific wiring harness with OEM. style connectors. Even if you have never made a modification to a vehicle, you can install a Unichip. It is no more challenging than hooking up a DVD player to your TV. Unichip system comes with step-by-step instructions that are clear and easy to follow.
Click to View Dyno Chart
on a stock 2006 MAZDASPEED 6
(chart showed 47bhp gain)
Brake Horsepower (BHP) is the measure of an engine's horsepower without the power loss caused by the transmission, gearbox, differential, water pump, and other auxiliary components such as alternator, power steering, and AC compressor. Thus the prefix "brake" refers to where the power is measured: at the engine's output shaft, as on an engine dynamometer. The actual horsepower delivered to the driving wheels is less. An engine would have to be retested to obtain a rating in another system. The term "brake" refers to the original use of a band brake to measure torque during the test (which is multiplied by the engine RPM and a scaling constant to give horsepower).
UNICHIP Q PERFORMANCE FEATURES
MAZDASPEED 6 Plug n Play wiring harness with factory connectors - installs in under 15 minutes with minor tools
Multi-processor computer for a new level of engine management
Custom-engineered software for the MS6 with your specific performance components
Adds power to stock & modified engines by just plugging it in
Works with a variety of cold air intakes, exhaust systems & other performance components
Dyno-tested and field-tested to ensure maximum reliability over the lifetime of your engine
Crafted to output power more smoothly, eliminating weak areas in the power curve
Safely maximizes engine power output across the entire RPM band
Does not permanently or temporarily alter factory computer software
Optional custom tunable by a Unichip Custom Tuner for custom components and the most power
No footprint on the stock ECU - Invisible installation, easily removable
Performance guaranteed to satisfy!
Equal or better gas mileage varies on modifications
One year Unichip warranty
Choose Your Map StreetUnit will offer multiple map options for your MAZDASPEED 6. We can program the map on your Unichip here before it leaves our facility. For future modifications to your vehicle, the Unichip can easily be remapped. You can send the Unichip unit back to us to be remapped or the vehicle can be taken to a local Unichip Tuner to load a map which we can email them.
Optional Unichip Certified Custom Tuning The Unichip offers the option to get local custom tuning performed on your MAZDASPEED 6. The Certified Custom Unichip Tuner can tune your MS6 with Windows-based tuning software to maximize the performance of your MS6 and modifications, creating the most power as possible.
S4poor
Postby S4poor » Fri Mar 21, 2008 9:14
<div class='quotetop'>QUOTE (firestoned @ Mar 21 2008, 08:29 AM) [url=index.php?act=findpost&pid=34393]<{POST_SNAPBACK}>[/url]</div>
Optional Unichip Certified Custom Tuning The Unichip offers the option to get local custom tuning performed on your MAZDASPEED 6. The Certified Custom Unichip Tuner can tune your MS6 with Windows-based tuning software to maximize the performance of your MS6 and modifications, creating the most power as possible.[/b]
Link?
firestoned
S4poor
<div class='quotetop'>QUOTE (firestoned @ Mar 21 2008, 08:42 AM) [url=index.php?act=findpost&pid=34395]<{POST_SNAPBACK}>[/url]</div>
Just found it, thank you.
arctic_blue83
Postby arctic_blue83 » Fri Mar 21, 2008 9:14
Me personally... I've never been a big fan of Unichip... it's just another piggyback adapted for the Speed6 platform, whereas the Standback was specifically designed for the DISI motor, if price were no issue, and I owned a Speed6 still, no doubt in my mind, I would buy a Standback long before I would buy a Unichip, just due to the engineering behind it, and the fact with the Standback allows you to tune your own car, whereas a Unichip can only be accessed by Unichip certified professionals.
I imagine it's a pretty good bang/buck, considering it costs a good bit less than the Standback w/PnP harness, but I would just save my cash for the Standback. Just my $.02
S4poor
<div class='quotetop'>QUOTE (arctic_blue83 @ Mar 21 2008, 09:02 AM) [url=index.php?act=findpost&pid=34399]<{POST_SNAPBACK}>[/url]</div>
I imagine it's a pretty good bang/buck, considering it costs a good bit less than the Standback w/PnP harness, but I would just save my cash for the Standback. Just my $.02[/b]
I agree, I just wanted to see the dyno plot.
No question the standback software is above and beyond a mass produced product for pretty much any make/model vehicle.
firestoned
thanks for the input
jdmsp
Postby jdmsp » Fri Mar 21, 2008 9:14
Yeah I have heard this as well with the msp. Depending on what your doing with your car though right?
Users browsing this forum: Baidu [Spider] and 76 guests
