I realized that as we work more and more on our cars that the oddball tools that are expensive or rarely needed also start to accumulate. I also realized we all could spread our funds further if we borrowed these tools instead of buying them all the time. There will certainly be times when a tool will need to be bought, but maybe a tool share thread would minimize that.
Thinking that the available tools would be listed by person. each person willing to loan a tool would list their location and what they are willing to share.
It should go without saying that the borrower should be familiar with the tool's use and make sure it returns in the same or better condition in a timely manner agreed to in advance.
EDIT: Please contact the person you would like to borrow a tool from through PM, not in the thread.
Tool Share
Re: Tool Share
Tools:
12 v trickle charger
fuel line decoupling set
rivet gun
steering wheel puller
Porter Cable RO polisher
universal overhead cam valve spring compressor
lisle spill free funnel
Tools:
rivet gun
Re: Tool Share
Tools:
rotary flywheel bolt wrench
54 mm rotary flywheel socket 3/4" drive with 1/2" adapter
NA rotary clutch alignment tool
Rotary rear counterweight puller
NA rotary flywheel stopper
Throttle Position Adjuster Tool - electrical loom with 2 lights for setting the TPS on 84-92's Rotary
I'll edit the list when I can look and see what else I have.
Tools:
Re: Tool Share
Tools:
Super strong impact and most other air tools
Most air tools
Timing tools for 2.3 MZR Turbo
whole car Lift (will need heads up before use)
Timing gun
OBD2 Reader and code clearer
Angle Grinders
Table Saws, chop saws, skill saws, sawzalls, etc.
Dewalt Buffing wheel
I'll add more as I remember them haha
Tools:
Most air tools
Timing gun
Angle Grinders
Re: Tool Share
Tools:
OBD2 Code reader
Timing light
Dewalt angle grinder
Porter Cable RO
Rivet Gun
Interior Panel removers
3 jaw gear pullers, various sizes
Oil filter wrench
pickle fork
Crowsfeet (metric and standard)
flex/hinged torx sockets
garage/driveway space for tech/detail/bbq meet
Tools:
OBD2 Code reader
Timing light
Porter Cable RO
Rivet Gun
Oil filter wrench
pickle fork
