Herro Prease!
I'm having a rythmic hum from my front driver-side wheel. Only at low speeds, and only when turning left does this happen. I drive the car fairly spirited, but it's only at 37k. Do the wheel bearings go out on these frequently? Or am I hearing a CV or something else?
Looking at RockAuto and other forums, I see that the wheel bearings are most likely press-fit. Should I buy the whole hub assembly? Also, RockAuto only has wheel bearings for the front, and hubs for the rear. I'm just a little confused, and would like to get a few things straight before buying the parts needed.
Thanks for all your help guys!
JT
Wheel Bearing
CV is usually a clicking noise when they start to go. I would lean towards wheel bearing also. but inspect your breaks closely while you have it up, I have seen the tension springs fail and grind on the disc this usually has a tinny sound though. If you are in the springs area I have a press you are welcome to use to press in/out races. Good luck!
