Wanted: fan thermo switch Connector with pigtail
Telluride
Junior Member
Postby Telluride » Thu Oct 30, 2014 9:14
I have a 94 rx7. while replacing my Ecu temp sensor and fan thermoswitch/thermistor, I found the thermistor(thermo fan switch, single wire, black clip, on the back of the thermostat housing) connector had broken off from the wiring harness. I need a clean, non broken, clip with pigtail, if possible. Used is fine. Need in route as soon as possible. I have pay pal ready! I am guessing, But a 89-91 FC thermistor clip/pigtail should work. I am installing a 89-91 FC thermistor to kick my fans on earlier and this is a direct replacement for the stock FD.
This is where the connector broke off from the wiring harness.
This is the sensor that I am replacing, which is what I need the connector to.
I wish I had a better picture from today, but the connector is round, black, and has a single wire.
Telluride
Junior Member
Also, If in the Denver area and you have a broken FD / S5 rx7, I can come pull it myself, if need be. ;)
Telluride
Junior Member
I found one on rx7club. :)
Users browsing this forum: Google [Bot] and 56 guests
